[mapserver-dev] Unable to access MapInfo TAB files or ESRI
Shape Files
sharat
sharat at firstcall.net
Tue Oct 20 12:00:08 EDT 2009
Hey Sumit,
That did help me. Thanks a lot for the help.
Sharat
Sumit Sharma wrote:
> I suggest to revisit your map file. your possible errors can be with style
> obj of your layer or with your map extents. If still you are not able to
> figure out, u can share your map file and shape file(s)
> Cheers,
> Sumit
> sharat wrote:
>> I am newbie to mapserver. I have MapInfo .tab files and also shape files.
>> When i try to access them as layers using an OGR connection, the layers
>> just don't show up. I am using the basic ITASCA demo that is available
>> for download. I've made according modifications and gave OGR connections.
>> I'm really not able to figure out the reason. I'm sure its a small issue,
>> but i'm just not able to get out of it.
>> If anyone could tell me the possible reasons for the layers not to show
>> up, i will look into them. Any help regd this is greatly appreciated.
>> Thanks,
>> Sharat
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
View this message in context: http://n2.nabble.com/Unable-to-access-MapInfo-TAB-files-or-ESRI-Shape-Files-tp3849353p3859513.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
