[mapserver-dev] MapServer Documentation and translation (spanish)
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Feb 15 21:08:24 EST 2010
Hello Juanma,
Thank you for volunteering your time - we would love to have your
assistance.  Here are some of the steps:
- provide me with your OSGeo User ID (which you can create at
https://www.osgeo.org/cgi-bin/ldap_create_user.py).
- I can then add commit privileges to your user ID
- then you should go through the documentation howto
(http://mapserver.org/development/documentation.html) and install Sphinx
locally, to generate the necessary HTML files from the raw restructured
text files. (and read through that entire howto document)
- checkout the docs from SVN locally (svn co
https://svn.osgeo.org/mapserver/trunk/docs/ docs --username yourosgeoid)
- copy the /en folder and rename to your language
- have fun!  :)
Hope this helps a little (others may also comment about necessary steps).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
Juanma M. R. wrote:
> Hi list,
> I can help with the translation of MapServer documentation to spanish if
> you need more people to do this task. I have seen that the ticket is
> asigned to jmckenna and I supposed he is in charged of coordinating this
> task but I don't know which is the following step for getting involved.
> Just visiting www.mapserver.org <http://www.mapserver.org> I found that
> it was necessary to get in touch with any of the MapServer developers to
> start working with MapServer SVN but I didn't find any email.
> So here I am: how can I help (if it is necessary) to translate MapServer
> documentation to Spanish?
