[mapserver-dev] MapServer Documentation and translation (spanish)
Juanma M. R.
juanma.mr at gmail.com
Tue Feb 16 07:54:48 EST 2010
Hi list,
Thanks Jeff. I already checked the SVN structured and I guessed it was only
a matter of copying and renaming english folder. Is there any one else
translating it? In order to avoid translating twice the same documments it
would be recommended to coordinate the translation, wouldn't it? I don't
know if Eduin or others are working on that.
In the meanwhile, my OSGeo User ID is juanmamr.
I will follow the steps and start working on it during this week.
Best regards,
Juanma.
2010/2/16 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Hello Juanma,
> Thank you for volunteering your time - we would love to have your
> assistance. Here are some of the steps:
> - provide me with your OSGeo User ID (which you can create at
> https://www.osgeo.org/cgi-bin/ldap_create_user.py).
> - I can then add commit privileges to your user ID
> - then you should go through the documentation howto (
> http://mapserver.org/development/documentation.html) and install Sphinx
> locally, to generate the necessary HTML files from the raw restructured text
> files. (and read through that entire howto document)
> - checkout the docs from SVN locally (svn co
> https://svn.osgeo.org/mapserver/trunk/docs/ docs --username yourosgeoid)
> - copy the /en folder and rename to your language
> - have fun! :)
> Hope this helps a little (others may also comment about necessary steps).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> Juanma M. R. wrote:
>> Hi list,
>> I can help with the translation of MapServer documentation to spanish if
>> you need more people to do this task. I have seen that the ticket is asigned
>> to jmckenna and I supposed he is in charged of coordinating this task but I
>> don't know which is the following step for getting involved. Just visiting
>> www.mapserver.org <http://www.mapserver.org> I found that it was
>> necessary to get in touch with any of the MapServer developers to start
>> working with MapServer SVN but I didn't find any email.
>> So here I am: how can I help (if it is necessary) to translate MapServer
>> documentation to Spanish?
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20100216/40f6ee2c/attachment.html
