[mapserver-dev] MS RFC 37: AUTO Projection Support
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Feb 22 14:47:34 EST 2010
Is there a plan to make this work with shapefile that have .prj file
outside of adding a gdal/ogr dependency?
While a love gdal/ogr, it is heavy in terms a package dependencies,
(unless something has changed), and often a struggle to add to
production sites that are not doing imagery.
This should be noted as appropriate. Since it is an opt-in feature I'm
good either way.
-Steve W.
Frank Warmerdam wrote:
> Howard Butler wrote:
>>> - I'm not sure if this is the same question as Frank's, but, what
>>> happens
>>> when no projection info can be read from the source file, when using
>>> PROJECTION AUTO?
> Jeff,
> Good question.
>> It will be an unfilled projectionObj, which is what a layer with no
>> PROJECTION object currently ends up with.
> Howard,
> I'm not sure I'm happy with this answer. If the person puts PROJECTION
> AUTO
> and MapServer just silently treats this as a layer with no projection
> information because there is nothing available from the file, this could
> be very misleading. I'd like to suggest instead that an error be issued
> by MapServer in this situation, suggesting the PROJECTION block be
> commented
> out or manually filled as MapServer is unable to automatically provide
> coordinate system information for the dataset in question.
> Also, we should ensure there is a nicely formatted debug message reporting
> on the projection value substituted for AUTO so that folks who are
> trying to peak under the hood will know what is actually happening.
> Best regards,
