[mapserver-dev] testing CLUSTER object
Tamas Szekeres szekerest at gmail.com
Thu Apr 14 16:43:53 EDT 2011
2011/4/14 Stephen Woodbridge <woodbri at swoodbridge.com>
> I was thinking about the issue of the cluster symbols getting clipped by
> tile edge effects and I think that we should treat symbols similar to labels
> and be able to say PARTIAL FALSE. The down side of this is that symbols near
> edges might never get drawn. Also, Am I correct in remembering the clusters
> are based on the features in the view, so a cluster on the right or left
> side of adjoining edges will be based on the meta-tile to the right or left
> which might make some strange effects.
> Tamas, you probably have a better read on this since you thought through
> the implementation in much more detail than I ever have.
Steve,
We should definitely increase the (meta)tile size with a buffer at least
with CLUSTER MAXDISTANCE in each directions otherwise not all of the
neighbouring features are considered during the cluster creation near to the
tile borders.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110414/20275019/attachment-0001.html
