[mapserver-dev] Implementation of the msCalculateScale
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Feb 17 11:10:28 EST 2011
Not sure if the ticket is just for the documentation or also for the
program option. I would like to have the option for native MapServer
too: I find it easier to use for map layout than WMS SLD. I always
considered the MapServer parser the best thing of MapServer.
Jan
On 2011-02-17 16:18, Lime, Steve D (DNR) wrote:
> I'll create a ticket to do so. When MapServer was originally written
> there was a companion program for imagery (imgserv) that
> was implemented using the Erdas Imagine C toolkit. I followed their
> lead at the time and it's stuck...
> "Would it make sense to add an option for MapServer to treat extents
> the same way as GDAL?" Sure, it's called WMS...
> Steve
> *From:*Jan Hartmann [mailto:j.l.h.hartmann at uva.nl]
> *Sent:* Thursday, February 17, 2011 9:18 AM
> *To:* Lime, Steve D (DNR)
> *Cc:* Mohamed Saâd HESSANE; mapserver-dev at lists.osgeo.org
> *Subject:* Re: [mapserver-dev] Implementation of the msCalculateScale
> Interesting. Could this be added to the documentation? It's important
> when you are scaling at pixel level. Would it make sense to add an
> option for MapServer to treat extents the same way as GDAL?
> Jan
> On 2011-02-17 16:07, Lime, Steve D (DNR) wrote:
> It's due to how MapServer interprets extents. It uses a pixel-center
> model  so you end up using width or height minus one in computations
> because
> an extent is from the center of the UL pixel to the center of LR pixel
> (you lose the "one" from the outside) . I've attached a graphic I
> created some time
> ago that illustrates the difference between a MapServer extent and the
> model GDAL and WMS use.
> Steve
> *From:*mapserver-dev-bounces at lists.osgeo.org
> <mailto:mapserver-dev-bounces at lists.osgeo.org>
> [mailto:mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *Mohamed
> Saâd HESSANE
> *Sent:* Thursday, February 17, 2011 4:41 AM
> *To:* mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> *Subject:* [mapserver-dev] Implementation of the msCalculateScale
> Good morning everybody.
> I don't understand how the msCalculateScale function in mapscale.c is
> implemented.
> As far as I know, the scale is calculated from the relation :
> inches_in_screen / inches_in_reallity.
> inches_in_screen : depend on the DPI and the width of the map;
> inches_in_reality : depend on the map.extent, and the pixel size.
> So why the "width-1" at the line 96? For me just "width" is more
> correct. Perhaps I'm wrong.
> The branches 4.X have just "width" in their implementations (line 125).
> So why the center pixel is removed from calculation?
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110217/7bf7a3fc/attachment-0001.html
