[mapserver-dev] INSPIRE Category Layer (may affect 6.0 release)
Martin Kofahl
m.kofahl at gmx.net
Sun Jan 23 07:16:43 EST 2011
Hi all,
if MapServer 6.0 shall support Inspire View Services, MapServer should
be able to serve named wms group layers as discussed elsewhere on this
list. Currently the wms_layer_group setting does not provide named group
layers. (And because of the nesting depth we cannot use the group keyword.)
Following ticket http://trac.osgeo.org/mapserver/ticket/1632 I propose
that the wms_layer_group keyword may reference a real map layer. This
change would not interfere present use of the wms_layer_group setting.
When wms_layer_group is evaluated, MapServer checks if a map layer with
such name is available. In this case msDumpLayer() will write the group
layer with all its capabilities and otherwise write only the title
(present behavior).
Compared to the use of the group keyword this technique requires
thoughtful map file configuration, because the a layer is not
necessarily the sum of all sub layers. This may also be an interesting
feature for some use cases. For the drawing process there are two
possible map file configurations:
a) Fully configured map layers shown as group in the capabilities. They
shall contain all data which the nested layers show. (Or even not if one
may present a simplified group layer in case of huge amount of nested
layers/data.)
b) Dummy group and nested layers. Drawing process is done by hidden
layers using the REQUIRES keyword, e.g. REQUIRES ([group] || [nested_layer])
Currently, the patch attached to #1632 dos not filter map-layers used as
group-layers beforehand. Thus group layers are currently dumped twice if
it's not hidden using #1952.
Martin
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110123/12bedb34/attachment.html
