[mapserver-dev] Documentation Question
Steve Lime
sdlime at gmail.com
Fri Jul 22 15:39:32 EDT 2011
I dunno, a running document like that is a pain in the ass to maintain IMHO
since you have to duplicate a lot of text and potentially try to explain
differences between versions. Why wouldn't it make sense to send folks using
5.4 to a concise set of documentation just for that version?
Steve
On Fri, Jul 22, 2011 at 6:51 AM, Jeff McKenna <jmckenna at gatewaygeomatics.com
> wrote:
> Hi Steve,
> My position is that the doc contents should contain references to the
> MapServer version that the feature applies to. So yes we should maintain
> backwards compatibility. For example, /mapfile/expressions.txt could be
> separated into "MapServer 6.0 Expressions" and "MapServer 5 Expressions"
> sections. I would argue that this is much easier to maintain, and makes
> more sense to a user. It does ask doc contributors and developers to
> specifically mention the MapServer version when they are documenting though.
> I'll give an example of what I mean:
> Let's say I am a mapscript dev and I add a function to a mapscript. Then
> I'd go to its doc (meaning: in trunk and also in branch-whatever-is-live-on-
> **web, because a user wants to know what is available) and add:
> GetXXX
> Added in MapServer version 6.2, this function gets the...
> I hope this helps clarify my position.
> -jeff
> On 11-07-21 1:42 PM, Steve Lime wrote:
>> Question for folks. What's our position regarding multi-version support
>> within the documentation? For example, there were a number of syntax
>> changes related to logical expressions in 6.0. We could update the
>> documentation to reflect 6.0 "as is" with no references to how things
>> worked in older versions. We could also try to maintain some backwards
>> compatibility so that the documentation could support all versions.
>> Doing so requires lots of extra explanation though and makes it harder
>> to maintain. If documentation is version specific then that would argue
>> for historical documentation to be made available...
>> ______________________________**_________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110722/a994fde9/attachment.html
