[mapserver-dev] MapServer 6.0.0-beta2 release
thomas bonfort thomas.bonfort at gmail.com
Wed Mar 23 08:38:21 EDT 2011
Havard provided me with the gdb backtrace off-list, I'll commit the fix asap.
thomas
On Wed, Mar 23, 2011 at 13:01, Daniel Morissette
<dmorissette at mapgears.com> wrote:
> On 11-03-23 06:19 AM, Havard Tveite wrote:
>> I use the default Ubuntu Apache2 distribution.
>> cgi, not fastcgi.
>>> Can you reproduce this crash using shp2img?
>> No, I have not been able to produce a crash using shp2img.
> Since you use the CGI and not FastCGI then the details of your Apache config
> should not make much difference, as long as the correct LD_LIBRARY_PATH is
> set to pick the right version of all support libs if they are not in the
> default system dirs.
> Can you reproduce the crash if you try one of the requests that fail using
> mapserv at the command line? e.g.
> mapserv "QUERY_STRING=map=...&mode=...&..."
> If yes then please run this in GDB (let us know if you need help with GDB)
> and create a ticket with the GDB 'backtrace' after the crash.
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
