[mapserver-dev] WCS 2.0 support and specification compliance
Andrea Aime
andrea.aime at geo-solutions.it
Fri Aug 17 06:54:18 PDT 2012
On Fri, Aug 17, 2012 at 2:49 PM, Fabian Schindler
<fabian.schindler at eox.at>wrote:
> Currently the "scaling" extension for WCS 2.0 is under discussion at the
> OGC WCS standards working group, and, once it is standardized, the "Size"
> and "Resolution" will likely have to be adjusted. (With the current state
> of the document, they will be replaced by the "scaleFactor", "scaleAxes"
> and "scaleDomain" parameters). I think the standard document is not
> publicly available, only in the OGC internal system.
> Thank you for the hint of putting the parameters into the "wcs:Extension"
> element. This was a recent change in the corrigendum that may not have been
> taken into account in the implementation.
Hi Fabian,
thanks a lot for the answer. Do you know if the XML schemas for these
extensions are available anywhere?
Also, is there any timeframe before OGC publishes the extensions as
official documents, or at least as RFCs?
Cheers
Andrea
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 962313
mob: +39 339 8844549
http://www.geo-solutions.it
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120817/257a2cd7/attachment-0001.html>
