[mapserver-dev] Re: MapCache seeding - mod_mapserver or
enable-mapserver?
thomas bonfort
thomas.bonfort at gmail.com
Wed Jan 18 08:59:37 EST 2012
Le 18 janv. 2012 20:04, "Smith, Michael ERDC-CRREL-NH" <
Michael.Smith at usace.army.mil> a écrit :
> For high thread cache seeding, what is the recommendation, using
mod-mapserver for wms or using the --enable-mapserver option in mapcache?
I'm assuming the direct enable mapserver option to avoid image re-encoding
etc.
Correct.
> I have been unable to get the experimental mapserver mode compiled into
mapcache. I get
I'll look into it at my return. The native libmapserver support has other
limitations that have to be worked out before it can be considered a usable
solution anyways.
> /bin/sh ../libtool --mode=link --tag CC gcc -rpath
/home/gridusr/local/lib ./cache_sqlite.lo ./ezxml.lo ./imageio_jpeg.lo
./configuration.lo ./service_ve.lo ./service_demo.lo ./source_wms.lo
./service_kml.lo ./source_mapserver.lo ./core.lo ./cache_disk.lo
./imageio_png.lo ./source_gdal.lo ./tileset.lo ./configuration_xml.lo
./service_tms.lo ./cache_tiff.lo ./dimension.lo ./lock.lo
./imageio_mixed.lo ./strptime.lo ./service_wmts.lo ./util.lo ./services.lo
./imageio.lo ./cache_memcache.lo ./source.lo ./image_error.lo ./http.lo
./service_wms.lo ./axisorder.lo ./image.lo ./buffer.lo ./grid.lo -lcurl
-lpng -ljpeg -L/u01/app/oracle/product/ofm/Oracle_WT1//lib -lapr-1
-L/u01/app/oracle/product/ofm/Oracle_WT1//lib -laprutil-1 -lsqlite3
-lpixman-1 -ltiff ../../libmapserver.la-o libmapcache.la
> libtool: link: you must specify an output file
> libtool: link: Try `libtool --help --mode=link' for more information.
> make[1]: *** [libmapcache.la] Error 1
> make[1]: Leaving directory
`/home/gridusr/local/src/mapserver/mapcache/lib'
> make: *** [all] Error 2
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120118/b124d95b/attachment.html
