[mapserver-dev] Motion: change default POSITION AUTO labelling order for point layers
thomas bonfort thomas.bonfort at gmail.com
Sun Mar 18 03:28:01 PDT 2012
Steve,
Adding this at the global level would not be particularly difficult to
implement, we'd just need to read these positions at the beginning of
the labelcache phase. However, I believe that such a customization
should be done at the label level, as the need to override the
accepted "best" positioning order would only need to be applied on a
very specific label layer.
thomas
On Fri, Mar 16, 2012 at 20:34, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> I have no idea what it would take to do something like this, but what do you
> think about adding a CONFIG "USE_ALT_LABEL_POSITION_AUTO=yes" or something
> like this in the mapfile as a global switch to an alternate hardcoded list
> of positions. Then by default you get the current positioning or select this
> in the mapfile to get the new positioning order. Assuming that it is easy to
> grab these config values, it is just an if block to reset the order on
> startup. I'm not sure if "startup" implies, reading the mapfile, or CGI or
> FastCGI, or apache module startup. Hopefully it is easy to init when the
> mapfile is read.
> -Steve W
> On 3/16/2012 1:42 PM, thomas bonfort wrote:
>> Patches graciously accepted :)
>> I personally have no incentive in implementing configurable positioning
>> as a hardcoded
>> 6 1 5
>> 4 X 3
>> 8 2 7
>> suits all my needs.
>> thomas
>> On Fri, Mar 16, 2012 at 16:30, Bob Basques <Bob.Basques at ci.stpaul.mn.us
>> <mailto:Bob.Basques at ci.stpaul.mn.us>> wrote:
>>    All,
>>    I know my vote doesn't count as much.  But I'm thinking the same
>>    here with regard to changing things.  As an alternative to changing
>>    things, what's the timeline on just setting up the planned MAPFILE
>>    controls instead?
>>    bobb
>>     >>> Daniel Morissette <dmorissette at mapgears.com
>>    <mailto:dmorissette at mapgears.com>> wrote:
>>    I'd say -0 ... I can see in ticket #4249 that the change of order gives
>>    better results in that case, but I am always hesitant to change a
>>    built-in behavior that has been around for years as this change could
>>    cause side-effects for other use cases where the current order is
>>    better. (I have no such use case in mind, just being overly careful
>>    because our users don't like when we break backwards compatibility.)
>>    BTW, I love the idea of a mechanism to control the order in the
>> mapfile.
>>    Daniel
>>    On 12-03-16 10:19 AM, thomas bonfort wrote:
>>     > Hi devs,
>>     > We have tickets 2981, 4242 and 4249 opened to ask for a change in
>> the
>>     > order which labels are placed around a label point, in order to
>>    obtain
>>     > better quality text placement.
>>     > http://trac.osgeo.org/mapserver/ticket/2981
>>     > http://trac.osgeo.org/mapserver/ticket/4242
>>     > http://trac.osgeo.org/mapserver/ticket/4249
>>     > While the long-term solution will allow us to configure this order
>> at
>>     > the mapfile level, I motion that we change this order from
>>     > 1 7 3
>>     > 6 X 5
>>     > 4 8 2
>>     > to
>>     > 6 1 5
>>     > 4 X 3
>>     > 8 2 7
>>     > for the 6.2 release.
>>     > I'll start with my +1.
>>     > regards,
>>     > thomas
>>     > _______________________________________________
>>     > mapserver-dev mailing list
>>     > mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>>     > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>    Daniel Morissette
>>    http://www.mapgears.com/
>>    Provider of Professional MapServer Support since 2000
