[mapserver-dev] Motion: change default POSITION AUTO labelling
order for point layers
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Mar 18 06:12:41 PDT 2012
The idea that I was trying to get across is the we have the current auto
position list that is global. You are proposing a change to a new auto
position list that is also global. So why not support both lists
globally via a CONFIG keyword to select the old one if the default list
is the new one, or vica versa.
This is easier than a patch for users that might need the old behavior
and do not have the ability to compile like on Windows.
I agree that long term this should be done at the label level. I was
only trying to think of a simple way around the objections.
Thanks,
-Steve
On 3/18/2012 6:28 AM, thomas bonfort wrote:
> Steve,
> Adding this at the global level would not be particularly difficult to
> implement, we'd just need to read these positions at the beginning of
> the labelcache phase. However, I believe that such a customization
> should be done at the label level, as the need to override the
> accepted "best" positioning order would only need to be applied on a
> very specific label layer.
> thomas
> On Fri, Mar 16, 2012 at 20:34, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> I have no idea what it would take to do something like this, but what do you
>> think about adding a CONFIG "USE_ALT_LABEL_POSITION_AUTO=yes" or something
>> like this in the mapfile as a global switch to an alternate hardcoded list
>> of positions. Then by default you get the current positioning or select this
>> in the mapfile to get the new positioning order. Assuming that it is easy to
>> grab these config values, it is just an if block to reset the order on
>> startup. I'm not sure if "startup" implies, reading the mapfile, or CGI or
>> FastCGI, or apache module startup. Hopefully it is easy to init when the
>> mapfile is read.
>> -Steve W
>> On 3/16/2012 1:42 PM, thomas bonfort wrote:
>>> Patches graciously accepted :)
>>> I personally have no incentive in implementing configurable positioning
>>> as a hardcoded
>>> 6 1 5
>>> 4 X 3
>>> 8 2 7
>>> suits all my needs.
>>> thomas
>>> On Fri, Mar 16, 2012 at 16:30, Bob Basques<Bob.Basques at ci.stpaul.mn.us
>>> <mailto:Bob.Basques at ci.stpaul.mn.us>> wrote:
>>> All,
>>> I know my vote doesn't count as much. But I'm thinking the same
>>> here with regard to changing things. As an alternative to changing
>>> things, what's the timeline on just setting up the planned MAPFILE
>>> controls instead?
>>> bobb
>>> >>> Daniel Morissette<dmorissette at mapgears.com
>>> <mailto:dmorissette at mapgears.com>> wrote:
>>> I'd say -0 ... I can see in ticket #4249 that the change of order gives
>>> better results in that case, but I am always hesitant to change a
>>> built-in behavior that has been around for years as this change could
>>> cause side-effects for other use cases where the current order is
>>> better. (I have no such use case in mind, just being overly careful
>>> because our users don't like when we break backwards compatibility.)
>>> BTW, I love the idea of a mechanism to control the order in the
>>> mapfile.
>>> Daniel
>>> On 12-03-16 10:19 AM, thomas bonfort wrote:
>>> > Hi devs,
>>> > We have tickets 2981, 4242 and 4249 opened to ask for a change in
>>> the
>>> > order which labels are placed around a label point, in order to
>>> obtain
>>> > better quality text placement.
>>> > http://trac.osgeo.org/mapserver/ticket/2981
>>> > http://trac.osgeo.org/mapserver/ticket/4242
>>> > http://trac.osgeo.org/mapserver/ticket/4249
>>> > While the long-term solution will allow us to configure this order
>>> at
>>> > the mapfile level, I motion that we change this order from
>>> > 1 7 3
>>> > 6 X 5
>>> > 4 8 2
>>> > to
>>> > 6 1 5
>>> > 4 X 3
>>> > 8 2 7
>>> > for the 6.2 release.
>>> > I'll start with my +1.
>>> > regards,
>>> > thomas
>>> > _______________________________________________
>>> > mapserver-dev mailing list
>>> > mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
>>> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> Daniel Morissette
>>> http://www.mapgears.com/
>>> Provider of Professional MapServer Support since 2000
