[mapserver-dev] Motion: change default POSITION AUTO labelling
order for point layers
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon Mar 19 11:07:21 PDT 2012
I don’t think this will be a disruptive change, people shouldn’t have gotten used to one way or another (although the regression tests will need updating) – it’s magic as far as they’re concerned. The order is not documented anywhere but in code. So I’d be ok with the change if you guys see a real benefit, +1. As an aside I believe the current order mimicked that of ArcPlot circa 1995.
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Friday, March 16, 2012 12:43 PM
To: Bob Basques
Cc: mapserver-dev at lists.osgeo.org; Daniel Morissette
Subject: Re: [mapserver-dev] Motion: change default POSITION AUTO labelling order for point layers
Patches graciously accepted :)
I personally have no incentive in implementing configurable positioning as a hardcoded
6 1 5
4 X 3
8 2 7
suits all my needs.
thomas
On Fri, Mar 16, 2012 at 16:30, Bob Basques <Bob.Basques at ci.stpaul.mn.us<mailto:Bob.Basques at ci.stpaul.mn.us>> wrote:
All,
I know my vote doesn't count as much. But I'm thinking the same here with regard to changing things. As an alternative to changing things, what's the timeline on just setting up the planned MAPFILE controls instead?
bobb
>>> Daniel Morissette <dmorissette at mapgears.com<mailto:dmorissette at mapgears.com>> wrote:
I'd say -0 ... I can see in ticket #4249 that the change of order gives
better results in that case, but I am always hesitant to change a
built-in behavior that has been around for years as this change could
cause side-effects for other use cases where the current order is
better. (I have no such use case in mind, just being overly careful
because our users don't like when we break backwards compatibility.)
BTW, I love the idea of a mechanism to control the order in the mapfile.
Daniel
On 12-03-16 10:19 AM, thomas bonfort wrote:
> Hi devs,
> We have tickets 2981, 4242 and 4249 opened to ask for a change in the
> order which labels are placed around a label point, in order to obtain
> better quality text placement.
> http://trac.osgeo.org/mapserver/ticket/2981
> http://trac.osgeo.org/mapserver/ticket/4242
> http://trac.osgeo.org/mapserver/ticket/4249
> While the long-term solution will allow us to configure this order at
> the mapfile level, I motion that we change this order from
> 1 7 3
> 6 X 5
> 4 8 2
> to
> 6 1 5
> 4 X 3
> 8 2 7
> for the 6.2 release.
> I'll start with my +1.
> regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120319/42e5b1b4/attachment-0001.html
