[mapserver-dev] [mapserver-users] Rendering Hindi Characters
Stephen Woodbridge woodbri at swoodbridge.com
Fri Apr 5 17:27:03 PDT 2013
Thomas, Ian,
Thanks for that, it fills in a lot of background. It also indicates that
we probably need work done to support Hindi that I was not aware of. So
opening a ticket to track this in mapserver is appropriate.
That article also implies that HarfBuzz is still not complete so we
might be trying to deal with a moving target, but at 90% complete it
might be better than what we have now if it is reasonable stable.
-Steve
On 4/5/2013 9:50 AM, thomas bonfort wrote:
> http://behdad.org/text/ is a good read if you haven't already stumbled
> upon it.
> thomas
> On 5 April 2013 15:45, Ian Walberg <ian.walberg at airborne.aero
> <mailto:ian.walberg at airborne.aero>> wrote:
>     Steve,
>     I will raise an issue to track this and we will be looking into it
>     in more detail.
>     From the research we have done so far I am not sure that it is an
>     issue with fribidi as my understanding that this just addresses
>     the l->r and r->l ordering issues.
>     What we believe is that the mapserver text rendering pipeline
>     cannot support the more complex character layouts required in some
>     cases for Hinidi and other languages.
>     Regards
>     Ian
>     -----Original Message-----
>     From: mapserver-dev-bounces at lists.osgeo.org
>     <mailto:mapserver-dev-bounces at lists.osgeo.org>
>     [mailto:mapserver-dev-bounces at lists.osgeo.org
>     <mailto:mapserver-dev-bounces at lists.osgeo.org>] On Behalf Of
>     Stephen Woodbridge
>     Sent: Friday, April 05, 2013 5:56 AM
>     To: mapserver-dev
>     Cc: mapserver-users at lists.osgeo.org
>     <mailto:mapserver-users at lists.osgeo.org>
>     Subject: Re: [mapserver-dev] [mapserver-users] Rendering Hindi
>     Characters
>     Ian,
>     As I mentioned before, I think this is an issue with fribidi or
>     the font that you are using. I have seen nothing that indicates
>     that this is a mapserver problem other than the implied suggestion
>     that maybe mapserver should find a different library to solve this
>     issue.
>     Did you post this issue on the fribidi list?
>     Did you post the response back here?
>     I saw that you tried the text in other windows products and it
>     works. I can appreciate your frustration with this fact, but this
>     does not in itself mean the mapserver is broken. We rely on
>     fribidi and the selected font to generate the correct glyphs for
>     rendering. If the gylphs are not rendered correctly there are a
>     few possibilities:
>     1. a bug in mapserver - not likely as we have plenty of working
>     examples using multiple other languages 2. a bug/limitation in
>     fribidi 3. a font file with missing or broken glyphs.
>     In most cases of rendering problems that we have seen to date have
>     been problems with fonts. The fribidi list has been helpful
>     identifying good fonts for specific languages.
>     If you want to file a bug on the mapserver site, goto
>     http://mapserver.org/ and follow the link on the top right of the
>     page to the issue tracker. You will need to supply a test case
>     that demonstrates the problem and some graphics so non hindi
>     readers can see what is bad and what is expected.
>     Without some more clear evidence that this is a mapserver problem,
>     I'm not sure this will get much action.
>     I am sympathetic, as I ran into a similar issue with Arabic a few
>     years ago and had to do this whole dance with fribidi to
>     understand the issues and identify a font that resolved the issues.
>     -Steve W
>     On 4/4/2013 11:12 AM, Ian Walberg wrote:
>     > Folks,
>     > Added the dev list, how do I raise a ticket on this?
>     > Thanks
>     > Ian
>     > From: mapserver-users-bounces at lists.osgeo.org
>     <mailto:mapserver-users-bounces at lists.osgeo.org>
>     > [mailto:mapserver-users-bounces at lists.osgeo.org
>     <mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Ian
>     > Walberg
>     > Sent: Tuesday, April 02, 2013 2:34 PM
>     > To: Stephen Woodbridge; mapserver-users at lists.osgeo.org
>     > Subject: Re: [mapserver-users] Rendering Hindi Characters
>     > Hello again list,
>     > The Hindi rendering problem has come to the top of our
>     priorities again and we have been investigating the cause of the
>     issue again.
>     > To recap the problem we are seeing can be reproduced easily,
>     paste Mexico City into google translate and then use the Hindi
>     characters with any Unicode font.
>     > The top (incorrect)  line of text is from mapserver and lower
>     > (correct) line is from Excel in this image
>     http://tinyurl.com/cs7pax5
>     >  From the research we have done freetype does not know how to
>     render all of these characters together correctly. It does appear
>     that pango can be configured to render them correctly.
>     > I have not yet dived into the details of the rendering pipeline
>     and I hope that someone can jump in and confirm we have a real
>     issue and there is not something stupid we have done.
>     > Many thanks
>     > Ian
>     <mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Stephen
>     > Woodbridge
>     > Sent: Wednesday, January 23, 2013 5:06 PM
>     > To: mapserver-users at lists.osgeo.org
>     > FYI, Mapserver does not do anything for rendering text except:
>     > 1. pass the text to fribidi which converts a utf8 sequence of
>     characters into a "displayable" sequence of characters.
>     > 2. mapserver then passes that to the text rendering function of
>     whatever renderer you are using.
>     > Mapserver does not try to understand it, it totally relies on
>     the underlying rendering code to do the right thing whatever that is.
>     > Thomas Bonfort might have some more insight into this as he
>     re-engineer a lot of the rendering pipeline and it might be
>     helpful to know what code is doing the actual text rendering. It
>     used to be freetype and may still be.
>     > I'm also not convinced the fribidi is not the right place for
>     this to happen regardless as it is responsible for taking a
>     sequence of characters and generating an "displayable" sequence
>     that can be rendered correctly given the correct font.
>     > -Steve
>     > On 1/23/2013 7:17 PM, Mr. Puneet Kishor wrote:
>     >> Peter,
>     >> My guru in all things Hindi fonts tells me that the problem
>     lies at the level where encodings are converted into font
>     renderings. Apparently, र् ट is a perfectly correct alternate
>     rendering of the unicode, just not Correct (with a capital C). I
>     have no idea where this happens with MapServer. Thankfully I've
>     never had to create a map with Hindi labels (I would be curious to
>     learn, perhaps off-list, who wants to see maps with Hindi labels),
>     but I too would like to see this resolved.
>     >> Hope someone knowledgable chimes in.
>     >> On Jan 23, 2013, at 3:58 PM, "Mr. Puneet Kishor"
>     <punk.kish at gmail.com <mailto:punk.kish at gmail.com>> wrote:
>     >>> (adding the list back to cc so brains better than mine may help)
>     >>> On Jan 23, 2013, at 3:47 PM, "Peter Mallen"
>     <peter.mallen at airborne.aero <mailto:peter.mallen at airborne.aero>>
>     wrote:
>     >>>> Hi Puneet,
>     >>>> I have passed the codes you have provided into MapServer
>      (U+0930 U+094D U+091F ) and it displays the characters
>     separately, not as one character.
>     >>>> This is how Map Server displays it: र् ट
>     >>> hmmm... well, then this is definitely above my pay grade.
>     Seems like you are doing the right thing, but my guess is
>     MapServer's Unicode implementation is not working properly.
>     >>> I don't see any mention of Unicode on mapserver docs page. The
>     only
>     >>> potentially relevant bit I see is
>     (http://www.mapserver.org/installation/unix.html#obtaining-the-neces
>     >>> s
>     >>> ary-software) that libgd should be compiled against the iconv
>     >>> library which provides full support for Unicode. On my MBA I get
>     >>>      $ ~ > gdlib-config --libs
>     >>>      -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng -lz -liconv
>     >>>> Thank You,
>     >>>> Peter Mallen
>     >>>> From: Mr. Puneet Kishor [mailto:punk.kish at gmail.com
>     <mailto:punk.kish at gmail.com>]
>     >>>> Sent: Wednesday, January 23, 2013 3:36 PM
>     >>>> To: Peter Mallen
>     >>>> On Jan 23, 2013, at 3:00 PM, "Peter Mallen"
>     wrote:
>     >>>>> Hi Puneet,
>     >>>>> I did try feeding MapServer the correct Unicode characters,
>     and it did fix the characters using what I believe is called the
>     "Reph" symbol (ि) but I could not get the conjunct consonants to
>     display correctly.
>     >>>> I have no idea what the above means ;-), but, did you try passing
>     >>>> U+0930 U+094D U+091F to MapServer? See
>     >>>> http://www.unicode.org/charts/PDF/U0900.pdf
>     >>>> U+0930 -> र -> r
>     >>>> U+094D ->  ् -> "halves" the previously typed r 091F -> ट -> thick
>     >>>> U+t sound
>     >>>>> Also, I have posted on the fribidi list and I believe it
>     does only help with bidirectional languages, but I could be wrong.
>     >>>>> Thank You,
>     >>>>> Peter Mallen
>     <mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Mr.
>     >>>>> Puneet Kishor
>     >>>>> Sent: Wednesday, January 23, 2013 12:27 PM
>     >>>>> On Jan 23, 2013, at 12:17 PM, Stephen Woodbridge
>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     >>>>>> On 1/23/2013 2:20 PM, Peter Mallen wrote:
>     >>>>>>> Hello Everyone,
>     >>>>>>> I am having issues rendering certain Hindi characters. I am
>     >>>>>>> using
>     >>>>>>> UTF-8 encoding.
>     >>>>>>> When attempting to display the following Hindi character in
>     >>>>>>> MapServer: र्ट
>     >>>>>>> It is rendered in MapServer as the following two characters: र्
>     >>>>>>> ट
>     >>>>>>> I believe these characters form what is called a conjunct
>     >>>>>>> consonant, of which there appear to be thousands of and
>     most of
>     >>>>>>> them do not render using MapServer.
>     >>>>>>> Also, It appears that MapServer is having an issue displaying
>     >>>>>>> these conjunct consonants and wants to display these
>     characters
>     >>>>>>> separately rather than to form them as one combined character.
>     >>>>>>> Here is a link describing more about the Devanagari alphabet:
>     >>>>>>> http://www.omniglot.com/writing/devanagari.htm
>     >>>>>>> Can anyone please help with this?
>     >>>>>>> Thank You,
>     >>>>>>> Peter Mallen
>     >>>>>> Hi Peter,
>     >>>>>> I can not speak to this specific problem but I can give you
>     and overview. Mapserver uses fribidi library for rending this data
>     and I know from working with Arabic that a lot depends on the font
>     you are using, in additional to the capabilities and version of
>     fribidi library.
>     >>>>> Isn't fribidi specifically for bidirectional languages?
>     Hindi is strictly LTR.
>     >>>>>> This kind of question is probably best asked on the fribidi
>     list as they will know more about what is supported or not for any
>     given language and they might be able to point you to a better font.
>     >>>>>> http://www.fribidi.org/
>     >>>>>> You should probably make sure you are using a recent
>     version of the library like 0.19.2 or better and be aware the
>     0.19.5 was released in Dec 2012.
>     >>>>> Peter, I forget where you and I left our off-list
>     conversation re. the issues you were having with rendering
>     Devnagari. Did you try feeding MapServer the correct Unicode
>     characters?
>     >>>>> Hope you figure this out.
>     >>>>> Puneet Kishor
>     >> _______________________________________________
>     >> mapserver-users mailing list
>     >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>     mapserver-dev mailing list
>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130405/0942d5f6/attachment-0001.html>
