[mapserver-dev] Issue with CMAKE plugin build
thomas bonfort
thomas.bonfort at gmail.com
Sun Mar 31 11:57:41 PDT 2013
Tamas,
>From the code in maporaclespatial.c both USE_ORACLESPATIAL and
USE_ORACLE_PLUGIN need to be defined in order for some of the needed code
to be activated. As there's no reference to the oracle_plugin stuff in the
unix makefiles, I'll infer that this is a windows only feature and suppose
that you can handle the dependencies in the cmake files as you wish.
regards,
thomas
On 31 March 2013 12:26, Tamas Szekeres <szekerest at gmail.com> wrote:
> I wanted to build mapserver with oraclespatial support to compile
> oraclespatial as a plugin, but that doesn't seem to work.
> Actually when setting WITH_ORACLE_PLUGIN=1, I also require to set
> WITH_ORACLESPATIAL=1 which causes that oracle is being built in mapserver
> directly. However, I don't want to build oracle in mapserver directly, just
> compile the oracle plugin (dll).
> IMHO we should be able to set the combination: WITH_ORACLESPATIAL=0 and
> WITH_ORACLE_PLUGIN=1. In this case we should get an additional module
> generated by cmake to compile the oracle plugin separately.
> The same should apply to the SDE and MSSQL plugins too.
> Best regards,
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130331/3a7ba8c4/attachment.html>
