[mapserver-dev] missing files using built-in OpenLayers template
Schylberg Lars lars.schylberg at saabgroup.com
Mon Jun 16 01:47:02 PDT 2014
You are right Jeff,
The openlayers script was missing in April and I asked that it would be put back.
It was recoverd but unfortunally the small images was not put back.
I started to use a local copy at the same time so I forgot to mention that as well.
/Lars S.
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: den 16 juni 2014 00:32
To: 'MapServer Dev Mailing List'
Subject: [mapserver-dev] missing files using built-in OpenLayers template
Hello all,
I have hit a wall, and I am hoping someone can confirm my suspicions.
When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
pan) are broken.  Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
Thanks all!
-jeff
PS. it would be odd if I am the first person to notice this in 2 months!!!
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
