[mapserver-dev] missing files using built-in OpenLayers template
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 16 05:27:54 PDT 2014
Still no luck, I would have thought that this OpenLayers single build
would look in the same directory for the img and theme folders.  Anyone
have any ideas?
-jeff
On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
> I have no idea how the website and github are linked now, but I just
> poked around the ProjectsVM and found that js file, so I copied the img
> and theme folders there: http://www.mapserver.org/lib/  ...but still no
> luck.  Will keep looking.
> -jeff
> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>> You are right Jeff,
>> The openlayers script was missing in April and I asked that it would be put back.
>> It was recoverd but unfortunally the small images was not put back.
>> I started to use a local copy at the same time so I forgot to mention that as well.
>> /Lars S.
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>> Sent: den 16 juni 2014 00:32
>> To: 'MapServer Dev Mailing List'
>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>> Hello all,
>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>> pan) are broken.  Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>> Thanks all!
>> -jeff
>> PS. it would be odd if I am the first person to notice this in 2 months!!!
