[mapserver-dev] missing files using built-in OpenLayers template
thomas bonfort
thomas.bonfort at gmail.com
Mon Jun 16 05:55:58 PDT 2014
Jeff,
The files are present now (c.f.
http://www.mapserver.org/lib/theme/default/) however there's something
wrong with our generated javascript as it's requesting the theme files
from http://server/cgi-bin/theme/default/style.css instead of
www.mapserver.org/lib/...
On 16 June 2014 14:27, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Still no luck, I would have thought that this OpenLayers single build
> would look in the same directory for the img and theme folders. Anyone
> have any ideas?
> -jeff
> On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
>> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
>> I have no idea how the website and github are linked now, but I just
>> poked around the ProjectsVM and found that js file, so I copied the img
>> and theme folders there: http://www.mapserver.org/lib/ ...but still no
>> luck. Will keep looking.
>> -jeff
>> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>>> You are right Jeff,
>>> The openlayers script was missing in April and I asked that it would be put back.
>>> It was recoverd but unfortunally the small images was not put back.
>>> I started to use a local copy at the same time so I forgot to mention that as well.
>>> /Lars S.
>>> -----Original Message-----
>>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>>> Sent: den 16 juni 2014 00:32
>>> To: 'MapServer Dev Mailing List'
>>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>>> Hello all,
>>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>>> pan) are broken. Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>>> Thanks all!
>>> -jeff
>>> PS. it would be odd if I am the first person to notice this in 2 months!!!
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
