[mapserver-dev] [gdal-dev] New env. var. to make it easier to test/debug web services
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Oct 2 13:18:27 PDT 2014
On 2014-10-02 5:09 PM, Even Rouault wrote:
> Le jeudi 02 octobre 2014 21:41:20, Jeff McKenna a écrit :
>> On 2014-10-02 4:24 PM, Even Rouault wrote:
>>> Le jeudi 02 octobre 2014 21:01:58, Even Rouault a écrit :
>>>> Le jeudi 02 octobre 2014 20:57:46, Lime, Steve D (MNIT) a écrit :
>>>>> How about making -nh set the environment variable programatically and
>>>>> losing the sendheaders checks?
>>>> Yes, that's a possibility. Although I think -nh could just call a
>>>> function to disable the boolean in msio instead of messing with
>>>> environmenet variables.
>>> I've just implemented that. So no more env. variable trick. Just the
>>> standard -nh mechanism.
>>> Would be cool to have a "mapserv --help" mode to display available
>>> options, wouldn't it ?
>> Would be super cool! It would list the -nh and -v options (I don't know
>> of other options).
> With my latest commit, and default configuration :
> $ mapserv --help
> Usage: mapserv [--help] [-v] [-nh] [QUERY_STRING=value]
> Options :
> -h, --help Display this help message
> -v Display version and exit.
> -nh Suppress HTTP headers in CGI mode.
> QUERY_STRING=value Set the QUERY_STRING in GET request mode.
> When compiled with -DMS_ENABLE_CGI_CL_DEBUG_ARGS
> $ mapserv --help
> [-tmpbase dirname] [-t mapfilename] [MS_ERRORFILE=value] [MS_DEBUGLEVEL=value]
> Options :
> -tmpbase dirname Define a forced temporary directory.
> -t mapfilename Display the tokens of the mapfile after parsing.
> MS_ERRORFILE=filename Set error file.
> MS_DEBUGLEVEL=value Set debug level.
Wow that is great.
Why limit the other options with a specific compile setting though?
>> The default message is, not fully correct:
>> "This script can only be used to decode form results and should be
>> initiated as a CGI process via a httpd server"
> Any suggestion ?
How about: "This script is commonly used to decode form results and
should be initiated as a CGI process via an httpd server. For other
options please try using the --help switch."
-jeff
