[mapserver-dev] [gdal-dev] New env. var. to make it easier to test/debug web services
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Oct 2 13:34:51 PDT 2014
On 10/2/2014 4:25 PM, Even Rouault wrote:
> Le jeudi 02 octobre 2014 22:18:27, Jeff McKenna a écrit :
>> On 2014-10-02 5:09 PM, Even Rouault wrote:
>>> Le jeudi 02 octobre 2014 21:41:20, Jeff McKenna a écrit :
>>>> On 2014-10-02 4:24 PM, Even Rouault wrote:
>>>>> Le jeudi 02 octobre 2014 21:01:58, Even Rouault a écrit :
>>>>>> Le jeudi 02 octobre 2014 20:57:46, Lime, Steve D (MNIT) a écrit :
>>>>>>> How about making -nh set the environment variable programatically and
>>>>>>> losing the sendheaders checks?
>>>>>> Yes, that's a possibility. Although I think -nh could just call a
>>>>>> function to disable the boolean in msio instead of messing with
>>>>>> environmenet variables.
>>>>> I've just implemented that. So no more env. variable trick. Just the
>>>>> standard -nh mechanism.
>>>>> Would be cool to have a "mapserv --help" mode to display available
>>>>> options, wouldn't it ?
>>>> Would be super cool! It would list the -nh and -v options (I don't know
>>>> of other options).
>>> With my latest commit, and default configuration :
>>> $ mapserv --help
>>> Usage: mapserv [--help] [-v] [-nh] [QUERY_STRING=value]
>>> Options :
>>> -h, --help Display this help message
>>> -v Display version and exit.
>>> -nh Suppress HTTP headers in CGI mode.
>>> QUERY_STRING=value Set the QUERY_STRING in GET request mode.
>>> When compiled with -DMS_ENABLE_CGI_CL_DEBUG_ARGS
>>> $ mapserv --help
>>> [-tmpbase dirname] [-t mapfilename] [MS_ERRORFILE=value]
>>> [MS_DEBUGLEVEL=value]
>>> Options :
>>> -tmpbase dirname Define a forced temporary directory.
>>> -t mapfilename Display the tokens of the mapfile after
>>> parsing. MS_ERRORFILE=filename Set error file.
>>> MS_DEBUGLEVEL=value Set debug level.
>> Wow that is great.
>> Why limit the other options with a specific compile setting though?
> I didn't change this. They are currently enabled conditionaly. I'm not sure
> why. Perhaps for security reasons, since they imply reading a file (-t),
> overriding the temporary directory (-tmpbase), creating a file (MS_ERRORFILE) ?
> /* Keep only "-v", "-nh" and "QUERY_STRING=..." enabled by default.
> * The others will require an explicit -DMS_ENABLE_CGI_CL_DEBUG_ARGS
> * at compile time.
>>>> The default message is, not fully correct:
>>>> "This script can only be used to decode form results and should be
>>>> initiated as a CGI process via a httpd server"
>>> Any suggestion ?
>> How about: "This script is commonly used to decode form results and
>> should be initiated as a CGI process via an httpd server. For other
>> options please try using the --help switch."
> Done
So does this change the default message from like:
http://example.com/cgi-bin/mapserv
No query information to decode. QUERY_STRING is set, but empty.
I think this should be kept the same and that the above message only get
displayed if it is run from the commandline. Which begs the question
what happens if it is called from a shell wrapper script?
-Steve W
>> -jeff
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
