[mapserver-dev] Allowing spaces in layer names (WMS/WFS)
Eichner, Andreas - SID
Andreas.Eichner at sid.sachsen.de
Thu Jul 2 06:43:11 PDT 2015
From WFS v1.1 Spec, section 9.2 GetFeature Operation / Request:
The mandatory typeName attribute is used to indicate the name of one or more feature type instances or class instances to be queried. Its value is a list of namespace-qualified names (XML Schema type QName, e.g. myns:School) whose value must match one of the feature types advertised in the Capabilities document of the WFS.
Optionally, individual feature type names in the typeName list may be aliased using the format QName=Alias.
And the QName production does not allow spaces.
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-
> bounces at lists.osgeo.org] Im Auftrag von Tamas Szekeres
> Gesendet: Donnerstag, 2. Juli 2015 14:16
> An: mapserver-dev at lists.osgeo.org
> Betreff: [mapserver-dev] Allowing spaces in layer names (WMS/WFS)
> Hi,
> Could anyone explain the reason of limiting the layer names to valid XML
> tag names (not containing spaces or any special characters in that)? As
> far as I know the layer names don't appear a XML tags in the OWS requests
> and I couldn't find such limitation in the WFS specs either.
> Many clients uses spaces in layer names and this is causing issues for us.
> Thanks,
> Tamas
