[mapserver-dev] Communicating Tile Coordinates Between Mapcache and Mapserver
thomas bonfort thomas.bonfort at gmail.com
Thu Jul 2 10:31:49 PDT 2015
On 2 July 2015 at 19:25, seandisanti <sdisanti at orionnetworksolutions.com> wrote:
> Thank you for the response, the suggested request string actually has the
> same result I was receiving last week, when I initially thought it was
> working. The entire layer looks to be compressed into the size of a tile.
the bbox= parameter is different for each tile. your viewer should
take care of constructing the correct bbox depending on where you are
on your map. re: use the demo and look at the urls being sent.
> I
> can send my config or mapfile, but for confidentiality purposes I can't post
> here. Is it alright to send directly to email?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Communicating-Tile-Coordinates-Between-Mapcache-and-Mapserver-tp5212572p5214051.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
