[mapserver-dev] Appveyor and MapScript tests
Bruno Friedmann
bruno at ioda-net.ch
Sat Mar 24 01:01:49 PDT 2018
On vendredi, 23 mars 2018 11.03:50 h CET Seth G wrote:
> Hi list,
> As part of the Bonn codesprint I've been attempting to get the Python
> MapScript unit tests working again, so test the new Python3 MapScript
> bindings. See https://github.com/mapserver/mapserver/pull/5569 As part of
> this I've added running the test suite to Appveyor. This change included
> updating to Visual Studio 2017 - hopefully this is fine with everyone. A
> final question relating to the MapScript Python3 bindings - to build these
> I had to use a newer version of SWIG (3.0.12). This seems to cause issues
> for the C# MapScript build on Appveyor, which runs fine with SWIG 1.3.39.
> If we want to automate the Python bindings can the C# bindings be disabled?
> If not does anyone have any experience getting these to work with a later
> version of SWIG?
> Regards,
> Seth
Hope you got fun at that codesprint.
Just a remark, are you forced to have SWIG 3.0.12 or 3.0.[5-10] is okay.
Bruno Friedmann
Ioda-Net Sàrl www.ioda-net.ch
Bareos Partner, openSUSE Member, fsfe fellowship
GPG KEY : D5C9B751C4653227
irc: tigerfoot
