[mapserver-dev] SWIG Changes for 7.4
Andy Colson
andy at squeakycode.net
Mon Apr 15 16:50:49 PDT 2019
On 4/15/19 11:25 AM, Seth G wrote:
> Hi Andy,
> The pull request in the MapServer queue looks good to me.
> For the additions at https://github.com/AndyColson/mapserver/commit/96ccb182b6750c7236c0448698dafc744e8c3eab there are quite a few whitespace/formatting differences which make it hard to see the actual changes.
> The NULL check looks fine in image.i
> For the removal of #ifdef SWIGPYTHON in msio.i - I presume this is to have the same feature in Perl? Do the C# and PHP bindings build successfully with this change? If so it seems fine to include it (otherwise I think you could use #if defined(SWIGPYTHON) || defined(SWIGPERL5) )
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Sun, Apr 14, 2019, at 10:47 PM, Andy Colson wrote:
>> On 4/14/19 3:01 PM, Andy Colson wrote:
>>> I know its pretty late in the game, but while testing perl mapscript, I found two little changes I'd like to make.
>>> Should I
>>> 1) add it to my existing pull request
>>> 2) create a new branch, and new pull request for 7.4
>>> 3) its too late for 7.4, wait
>>> I have perl test's that use the swig changes, so I can't add them yet either.
>>> -Andy
>> So that you can see the changes:
I can't build with C# or PHP, so I dunno, but I cant image it would cause problems. Does anyone know why the #ifdef's were added in the first place? I've removed them and tested with perl just fine.
I could add those changes to my pull request and have travis test it. Should I?
I'm aware of the spacing, but it was messed up a bit and I think it would be great to clean it up a little.
-Andy
