[mapserver-dev] tinyows improvements - question about shp2pgsql
Even Rouault even.rouault at spatialys.com
Fri Jun 18 11:50:25 PDT 2021
Le 18/06/2021 à 20:29, Bruno Friedmann via mapserver-dev a écrit :
> Hello the team, refreshing the packaging for openSUSE of tinyows I was finding
> some hicups I would (will try) to fix.
> Here's my list of wishes :-) normally each one will got a proper issue, then a
> pr.
> - move away from pg_config as stricto senso tinyows is not a server extension
> it's just a client so using pkg-config(libpq) should be enough.
> I will get inspired by what have been done last year in gdal.
Sounds good
> - shp2pgsql : I (re)discovered that shp2pgsql is a mandatory element, who
> remember why, or which feature use it ?
It is just needed if you want to run the tests, to load the test database.
> Thanks for any advise or element that would help me.
http://www.spatialys.com
