[mapserver-dev] MS RFC 133: Mapfile Syntax Cleanup
Even Rouault
even.rouault at spatialys.com
Tue Mar 30 14:02:01 PDT 2021
I'm +1 on the RFC
Even
Le 30/03/2021 à 22:57, Seth G a écrit :
> Hi Steve,
> I'm not sure where I got CLASS MAXSCALE from - it is not a property of
> the classObj or referenced anywhere in the sourcecode/tests. I'll
> remove from the RFC.
> Anyone else on the PSC more votes on this?
> I'm tempted to merge https://github.com/MapServer/MapServer/pull/6264/
> <https://github.com/MapServer/MapServer/pull/6264/> (this is mainly
> Steve's work, and then I updated the msautotests), it touches a lot of
> files so may need to be rebased quite often if not merged soon.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Mon, Mar 29, 2021, at 4:54 PM, Steve Lime wrote:
>> Hi Seth: In general I'm a strong +1 on this, anything that simplifies
>> the code base is a good thing.. Only one I wonder about is /CLASS
>> MAXSCALE/ since MINSCALE is currently supported as well? Personally
>> I'm selfish and I really like the MINSCALE/MAXSCALE aliases so
>> retaining those across the board would save me a ton of work when 8.0
>> arrives.
>> --Steve
>> On Tue, Mar 16, 2021 at 6:08 PM Seth G <sethg at geographika.co.uk
>> <mailto:sethg at geographika.co.uk>> wrote:
>> Hi all,
>> I've made a start of implementing RFC 133 [1] by removing the now
>> redundant LAYER DUMP keyword [2].
>> It would be good to get some votes in before proceeding further
>> in case people have objections to the overall aim of removing
>> deprecated keywords for the 8.0 release.
>> Any objections to specific keywords being removed can be raised
>> on individual pull requests.
>> Seth
>> [1] https://mapserver.org/development/rfc/ms-rfc-133.html
>> <https://mapserver.org/development/rfc/ms-rfc-133.html>
>> [2] https://github.com/MapServer/MapServer/pull/6264
>> <https://github.com/MapServer/MapServer/pull/6264>
>> web:http://geographika.co.uk <http://geographika.co.uk>
>> On Tue, Feb 2, 2021, at 11:18 PM, Seth G wrote:
>>> Hi Steve,
>>> If you could do a reference pull request I can use this as a
>>> template for the other keywords.
>>> I guess it needs a vote before accepting, so I'll start with my
>>> +1 - removing ambiguity around keywords will help new MapServer
>>> users. I was adding the DUMP keyword to all LAYER configs for
>>> several years "just in case"...
>>> Seth
>>> On Tue, Feb 2, 2021, at 12:31 AM, Steve Lime wrote:
>>>> I don't recall any keyword removals specifically. Should have
>>>> to touch:
>>>> * maplexer.l to remove keywords from the grammar
>>>> * mapfile.c/mapfile.h to remove read/write cases and symbols
>>>> * mapserver.h to remove structure members
>>>> Updating the maplexer.l effectively stops support, the rest is
>>>> just cleanup. I'll commit to taking a run through all of these
>>>> in the next day or so. It's a long list...
>>>> --Steve
>>>> On Fri, Jan 29, 2021 at 3:06 PM Seth G <sethg at geographika.co.uk
>>>> Hi all,
>>>> I've got round to a draft RFC for cleaning up deprecated
>>>> and legacy Mapfile keywords, based on current docs and
>>>> going through all the allowed syntax as part of mappyfile
>>>> development and ongoing MapScript docs updates.
>>>> It might be too early to vote on the RFC without some
>>>> discussion about which keywords should be removed.
>>>> In terms of updates any keyword removal would be a separate
>>>> pull request. The changes to mapfile.c seem fine (and the
>>>> msautotest Mapfiles), but I've never used the
>>>> lexer/parser/Bison process. Are there any sample commits
>>>> when a Mapfile keyword has been removed previously?
>>>> Thoughts/comments welcome,
>>>> Seth
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> <mailto:mapserver-dev at lists.osgeo.org>
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210330/cc943899/attachment-0001.html>
