[mapserver-dev] Questions about MapCache CI
Even Rouault even.rouault at spatialys.com
Tue Oct 12 09:41:48 PDT 2021
Hi Jérome,
it might be worth looking at porting to github action workflows
(examples at
https://github.com/MapServer/MapServer/tree/main/.github/workflows),
since Travis-CI is no longer super open source friendly. Targeting focal
only or bionic+focal would be reasonable.
Even
Le 12/10/2021 à 17:57, jbo-ads a écrit :
> While working on some MapCache issues I would like to fix, I am
> puzzled at auto tests that are run by Travis CI, in particular the
> distributions on which those tests are executed: precise, trusty and
> xenial. All three are phased out.
> Before starting a clean-up I would like to know if there is a point in
> keeping that. I see that MapServer already switched to bionic. Should
> I consider focal as well?
> Thank you for sharing your thoughts.
> Jérome.
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
More information about the MapServer-dev mailing list
