[mapserver-dev] MapServer 8.0 Beta Release?
Even Rouault even.rouault at spatialys.com
Wed May 11 09:41:01 PDT 2022
Le 11/05/2022 à 18:25, Steve Lime a écrit :
> Re-visiting this - I'm not sure what's blocking us moving forward
> w/beta. I see 4 open pull requests...
>  1. FlatGeobuf - would be nice to include in 8.0 although we could
>     target 8.2 if it might take awhile. There's no reason an 8.2
>     couldn't follow on fairly quickly.
Agreed: 8.2 material. We should consider ourselves in feature freeze
>  1. coshp utility - IMHO it could be merged "as is" and then open a
>     separate ticket to add tests.
Paul was wondering if it wouldn't be actually better hosted in shapelib
>  1. CMake policy warnings - seems like a blocker
Not sure if this a blocker. The related PR is indeed not passing. But
without it, if the issue is just warnings and not actual errors /
non-functional builds, we can perhaps live with that. I'll try to see if
I can try to advance this PR. It seems the remaining issue is with
mapscript python tests.
>  1. remove PHP-native MapScript - seems like a blocker
Probably a blocker indeed. Isn't the issue more on updating CI than the
actual removal of the PHP-native bindings ? Perhaps a compromise if
updating the CI to PHPNG is too hard would be to drop testing support of
PHP in CI, at least temporary even if that's not ideal.
> There are other bugs of course (there will always be bugs) but I don't
> consider those to be blockers for a release - other opinions welcome.
> --Steve
> On Tue, Mar 1, 2022 at 7:07 PM Steve Lime <sdlime at gmail.com> wrote:
>     Hi all: Seems like things for 8.0 are in a good place. Thoughts on
>     an initial beta release this week? —Steve
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220511/2b01c601/attachment.htm>
More information about the MapServer-dev mailing list
