[MapServer-dev] Missing license for the documentation repository
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Feb 6 05:42:18 PST 2023
Hi Even,
Thanks for your quick feedback. As mentioned by Jukka, the 4.0 series
was released to handle copyleft trolls, and makes many improvements,
which I believe are worth while for the hassle of upgrading to 4.0.
Therefore as you mentioned, I will begin a motion in a separate thread,
to the PSC. Thanks for the quick feedback on this.
-jeff
On 2023-02-06 9:35 a.m., Even Rouault wrote:
> Hi,
> Playing the devil's advocate, I'm not sure we can upgrade the license
> that easily given that there's no copyright assignment to an entity (the
> PSC typically) that could make such decisions on behalf of contributors.
> Formally, past contributors have agreed to contribute to the terms of
> 3.0 only, not necessarily 4.0. This is probably just nitpicking, and
> nobody will likely complain of a CC BY SA 3.0 -> CC BY SA 4.0 change,
> but I'd say at a minimum this should be conditioned to a formal PSC
> vote, so that the PSC holds the responsibility of the license version
> change.
> Even
> Le 06/02/2023 à 14:27, Jeff McKenna a écrit :
>> As Jukka pointed out, it's a good time to upgrade to version 4.0 of
>> the license (handled through
>> https://github.com/MapServer/MapServer-documentation/pull/796 )
>> Thanks all,
>> -jeff
>> On 2023-02-05 10:45 a.m., Jeff McKenna wrote:
>>> errr (I'm having a bad day it seems)......the repo license is
>>> actually in /en/copyright.txt and covered by CC BY SA)
>>> Closing that Pull Request.
>>> Again, my apologies. Darn. I'll try to clarify this in the
>>> README.md now, instead.
>>> -jeff
>>> On 2023-02-05 10:37 a.m., Jeff McKenna wrote:
>>>> Hi devs,
>>>> The MapServer-documentation repository is actually missing a
>>>> license. I have created a Pull Request to add a license, which is
>>>> actually the CC BY 4.0 license :
>>>> - pull request:
>>>> https://github.com/MapServer/MapServer-documentation/pull/793
>>>> - about CC BY 4.0 : https://creativecommons.org/licenses/by/4.0/
>>>> This license was chosen because it is the most permissive
>>>> CreativeCommons license.
>>>> I'm just sharing here, as most devs don't follow that issue tracker
>>>> for docs.
>>>> (needless to say, all documentation requires a license, and our
>>>> MapServer Documentation repo is actually shared quite often in other
>>>> projects)
>>>> Thanks,
>>>> -jeff
More information about the MapServer-dev
