[MapServer-dev] RFC-140 - MapServer Homepage
jbo-ads at mailo.com
Tue Mar 11 07:00:41 PDT 2025
+1
Jérome
On 3/9/25 16:57, Seth G via MapServer-dev wrote:
> Hi all,
> I've added in the feedback from the comments above to RFC 140 [1], see
> diff of changes at [2].
> I'd like to now formally propose to adopt this RFC, starting with my +1.
> Seth
> [1] https://mapserver.org/development/rfc/ms-rfc-140.html
> [2] https://github.com/MapServer/MapServer-documentation/pull/1000/files
> web:https://geographika.net & https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> On Wed, Jan 22, 2025, at 4:40 PM, Tom Kralidis wrote:
>> Thanks Seth.
>> RE: service-meta: I would still keep to the link conventions (proper
>> media type for "type", we could add a custom "service-type=WMS"
>> property), and include an href as well.
>> ..Tom
>> On Wed, Jan 22, 2025 at 10:27 AM Seth G <sethg at geographika.co.uk> wrote:
>> Thanks Tom - that pygeoapi pull request is good timing!
>> After reviewing and reading some of the associated documents, I'm
>> planning to update the RFC with the notes below.
>> pygeoapi has implemented a JSON service for their homepage at [1]
>> (pull request at [2].
>> This implements the api-catalog, a draft IETF (Internet
>> Engineering Task Force) standard [3].
>> The Link Set format is described at [4]. It is proposed this
>> approach is used to generate JSON for a MapServer "homepage".
>> The generated JSON format can be seen at
>> https://demo.pygeoapi.io/api-catalog.json, with an extract below:
>> "linkset": [
>> "anchor": "https://demo.pygeoapi.io/master",
>> "service-desc": [
>> "href": "https://demo.pygeoapi.io/master/openapi?f=json",
>> "title": "pygeoapi - latest GitHub 'master' version
>> (JSON)",
>> "type": "application/vnd.oai.openapi+json"
>> "service-doc": [
>> "href": "https://demo.pygeoapi.io/master/openapi?f=html",
>> (HTML)",
>> "type": "text/html"
>> The spec allows for an additional "service-meta" property "used
>> to link to additional metadata about the API,
>> and is primarily intended for machine consumption." I think this
>> can be used to add any additional properties from Mapfiles
>> we'd need to generate a MapServer homepage.
>> "service-doc" isn't mandatory, so WxS service links can ignore
>> this. An example of the proposed JSON and metadata is shown below:
>> "linkset": [
>> "anchor": "https://demo.mapserver.org/",
>> "service-desc": [
>> "href":
>> "https://demo.mapserver.org/cgi-bin/msautotest?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>> <https://demo.mapserver.org/cgi-bin/msautotest?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>> "title": "World WMS service",
>> "type": "text/xml"
>> "service-meta": {
>> "type": "wms",
>> "title": "WMS demo server for MapServer, used in the
>> msautotest suite",
>> "keywords": ["layers", "list"],
>> "mapfile": "msautotest.map",
>> Seth
>> [1] https://demo.pygeoapi.io/
>> [2] https://github.com/geopython/demo.pygeoapi.io/pull/60/files
>> [3]
>> https://datatracker.ietf.org/doc/draft-ietf-httpapi-api-catalog/08/
>> [4] https://www.rfc-editor.org/rfc/rfc9264.html
>> On Sun, Jan 19, 2025, at 5:10 PM, Tom Kralidis wrote:
>>> Seth: thanks for this RFC. IETF has api-catalog (draft, [1])
>>> which I think would be a good candidate for this RFC. This is
>>> also an item for review in the OGC API - Records SWG [2].
>>> Overall it looks pretty close to the RFC proposal. We can
>>> consider using api-catalog as a baseline and we can extend the
>>> JSON accordingly as needed for anything specific to our needs.
>>> Cheers
>>> ..Tom
>>> [1] https://datatracker.ietf.org/doc/draft-ietf-httpapi-api-catalog
>>> [2] https://github.com/opengeospatial/ogcapi-records/issues/355
>>> On Sat, Jan 18, 2025 at 5:39 PM Seth G via MapServer-dev
>>> <mapserver-dev at lists.osgeo.org> wrote:
>>> Looking again at the landing page JSON at
>>> https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi?f=json
>>> it is in the same format, so as you suggested could simply
>>> be expanded with links to WxS services, or even CGI
>>> generated responses. This would also more easily allow
>>> template reuse.
>>> Seth
>>> On Sat, Jan 18, 2025, at 11:33 PM, Seth G via MapServer-dev
>>> wrote:
>>> > Hi Even,
>>> > Thanks for your valuable feedback.
>>> > The homepage would be a "superset" of all available
>>> Mapfiles in a
>>> > MapServer deployment, as listed in the CONFIG file. Each
>>> individual
>>> > Mapfile would still have its own OGC API landing page, so
>>> the homepage
>>> > is best described as a directory of all landing pages.
>>> > As most MapServer deployments will likely be serving out a
>>> combination
>>> > of WxS and new OGC API services for some time to come, it
>>> will allow
>>> > both types to be listed together (I'm unaware of a OGC API
>>> spec that
>>> > would cover this).
>>> > In regard to the JSON used for links, I was modelling it
>>> as closely as
>>> > possible to OGC API conventions. Looking at the pygeoapi
>>> demo home
>>> > page, it provides a set of links in a common format, so
>>> I'll likely
>>> > switch to this format/approach:
>>> > https://demo.pygeoapi.io/stable?f=json
>>> > A few of the "rel" values are defined as below, and can be
>>> reused:
>>> > alternate Provides an alternate representation (e.g.,
>>> HTML version of a
>>> > resource).
>>> > service-desc Links to the machine-readable API
>>> description (e.g.,
>>> > OpenAPI JSON).
>>> > service-doc Links to the human-readable API
>>> documentation (e.g.,
>>> > OpenAPI HTML).
>>> > conformance Lists the standards and conformance classes
>>> supported by
>>> > the API.
>>> > I'll update the RFC with the above,
>>> > Seth
>>> > On Sat, Jan 18, 2025, at 12:39 PM, Even Rouault wrote:
>>> >> Seth,
>>> >> Thanks for putting this together. I'm wondering how much
>>> your proposal
>>> >> relates/intersects with the concept of the landing page
>>> of OGC API
>>> >> services ? You mention some connection with it, but it is not
>>> >> immediately clear to me the exact nature of the
>>> connection. Perhaps it
>>> >> is just a matter of clarifying. I have put zero thoughts
>>> in it, but it
>>> >> would feel weird to invent a MapServer specific thing, so
>>> I'm naively
>>> >> wondering if we can't we just adopt the landing page
>>> formalism (for the
>>> >> JSON part), and potentially extend it by exposing old WxS
>>> services as
>>> >> well in the links as you suggest? I'm also wondering if
>>> there's some
>>> >> best practice used by other projects on how to expose for
>>> things like
>>> >> "href":
>>> "https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>>> <https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>>> >> "title": "GetCapabilities",
>>> >> "type": "WMS"
>>> >> so they can be interoperably consumed.
>>> >> Even
>>> >> Le 18/01/2025 à 09:11, Seth G via MapServer-dev a écrit :
>>> >>> Hi devs,
>>> >>> I've drafted an RFC with an approach of creating a
>>> MapServer homepage based on the MAPs referenced in a
>>> mapserver.conf file. This will allow MapServer installations
>>> to easily advertise available services, dynamically.
>>> >>> Text available in pull request at
>>> https://github.com/MapServer/MapServer-documentation/pull/996
>>> >>> Comments and thoughts appreciated,
>>> >>> Thanks,
>>> >>> Seth
>>> >>> _______________________________________________
>>> >>> MapServer-dev mailing list
>>> >>> MapServer-dev at lists.osgeo.org
>>> >>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> >> http://www.spatialys.com
>>> >> My software is free, but my time generally not.
>>> >> Butcher of all kinds of standards, open or closed
>>> formats. At the end,
>>> >> this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250311/6f4a1ad2/attachment-0001.htm>
More information about the MapServer-dev
