[MapServer-dev] RFC-140 - MapServer Homepage
Daniel Morissette
dmorissette at mapgears.com
Mon Mar 17 17:18:58 PDT 2025
I like the idea of using PATH_INFO to control this, and "index" sounds
like a good option as the default value as you suggested. I'm also fine
with picking from the other names that were suggested.
On 2025-03-13 06:22, Seth G wrote:
> Thanks all for the votes and feedback.
> I'm not sure why I went with the ?mode=config&f=json approach - using
> the URL path would be a better fit, as I'm trying to follow the OGC API
> approach as much as possible. Allowing Mapfile references in the index
> was added in [1].
> Daniel - I agree "config" could be confusing, and may be better used for
> working with the CONFIG directly. I'm now no longer that keen on
> "homepage" either! Maybe "index" would be a better fit, similar to the
> root of a website defaulting to index.html.
> Alternatively, I've just been testing out allowing the homepage/index at
> the root of MapServer, if the MS_HOMEPAGE_TEMPLATE_DIRECTORY is set. The
> index would then be returned with an empty URL such as
> http://localhost/mapserver/ <http://localhost/mapserver/>. This would
> also avoid returning the "loadParams(): Web application error. No query
> information to decode. QUERY_STRING is set, but empty. " message.
> [1] https://github.com/MapServer/MapServer/pull/6862 <https://
> github.com/MapServer/MapServer/pull/6862>
> web:https://geographika.net <https://geographika.net> & https://
> mapserverstudio.net <https://mapserverstudio.net>
> mastodon: @geographika at mastodon.social <mailto:geographika at mastodon.social>
> On Tue, Mar 11, 2025, at 5:46 PM, Lime, Steve D (MNIT) via MapServer-dev
> wrote:
>> The path after the binary name is available to you through an
>> environment variable (PATH_INFO) as part of normal web server
>> processing. We leverage that for OGC API support. In this case, you’d
>> just look at the first component of the PATH_INFO and see if it
>> matches your keyword (e.g. homepage) and then process accordingly (if
>> enabled). Otherwise the first component of PATH_INFO is interpreted as
>> the mapfile (more typically the mapfile alias) – Seth added that
>> support in 8.2 (I think).
>> *From:*Richard Greenwood <richard.greenwood at gmail.com>
>> *Sent:* Tuesday, March 11, 2025 11:35 AM
>> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>
>> *Cc:* Daniel Morissette <dmorissette at mapgears.com>; mapserver-
>> dev at lists.osgeo.org
>> *Subject:* Re: [MapServer-dev] RFC-140 - MapServer Homepage
>> On Tue, Mar 11, 2025 at 8:47 AM Lime, Steve D (MNIT) via MapServer-dev
>> <mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>>
>> wrote:
>> One idea might be to support a more restful URL, e.g. https://
>> myhost.com/cgi-bin/mapserv/homepage <https://myhost.com/cgi-bin/
>> mapserv/homepage> (or /home or /index or ?) instead of using a
>> parameter-based approach. Maybe that endpoint name could be
>> configurable via the config file – and that could also enable the
>> functionality.
>> Steve, correct me if I'm wrong, but that seems like it's getting into
>> the realm of the web server. Like how is the mapserv binary to know
>> that it should look for, and process, stuff after the "/"? What
>> happens for example with "cgi-bin/mapserv.fcgi/homepage"? Does Apache
>> know that I want to run the mapserv binary in fcgi mode and also know
>> to pass the "homepage" part to the binary as a parameter? I like the
>> idea of a restful syntax but I can't get my head around the
>> implementation.
>> Rich
>> *From:*MapServer-dev <mapserver-dev-bounces at lists.osgeo.org
>> <mailto:mapserver-dev-bounces at lists.osgeo.org>> *On Behalf Of
>> *Daniel Morissette via MapServer-dev
>> *Sent:* Monday, March 10, 2025 4:58 PM
>> *To:* mapserver-dev at lists.osgeo.org <mailto:mapserver-
>> Hi everyone,
>> Sorry for being late with my feedback. I like the RFC overall,
>> but was wondering if we could find a better trigger than
>> mode=config for this feature. My first reaction when I saw
>> mode=config was that this mode could be used to deal with the
>> actual config settings in the future if we ever want to go there
>> so using mode=config today for this homepage feature could limit
>> our future options. That being said, I couldn't find any good
>> names other than mode=homepage to match the
>> MS_HOMEPAGE_TEMPLATE_DIRECTORY variable that controls it.
>> I can live with mode=config if we have no better option and am +1
>> with the RFC otherwise.
>> Daniel
>> On 2025-03-09 11:57, Seth G via MapServer-dev wrote:
>> Hi all,
>> I've added in the feedback from the comments above to RFC 140
>> [1], see diff of changes at [2].
>> I'd like to now formally propose to adopt this RFC, starting
>> with my +1.
>> Seth
>> [1] https://mapserver.org/development/rfc/ms-rfc-140.html
>> <https://mapserver.org/development/rfc/ms-rfc-140.html>
>> [2] https://github.com/MapServer/MapServer-documentation/
>> pull/1000/files <https://github.com/MapServer/MapServer-
>> documentation/pull/1000/files>
>> web:https://geographika.net <https://geographika.net/> &
>> https://mapserverstudio.net <https://mapserverstudio.net/>
>> On Wed, Jan 22, 2025, at 4:40 PM, Tom Kralidis wrote:
>> Thanks Seth.
>> RE: service-meta: I would still keep to the link
>> conventions (proper media type for "type", we could add a
>> custom "service-type=WMS" property), and include an href
>> as well.
>> ..Tom
>> On Wed, Jan 22, 2025 at 10:27 AM Seth G
>> <sethg at geographika.co.uk <mailto:sethg at geographika.co.uk>>
>> wrote:
>> Thanks Tom - that pygeoapi pull request is good timing!
>> After reviewing and reading some of the associated
>> documents, I'm planning to update the RFC with the
>> notes below.
>> pygeoapi has implemented a JSON service for their
>> homepage at [1] (pull request at [2].
>> This implements the api-catalog, a draft IETF
>> (Internet Engineering Task Force) standard [3].
>> The Link Set format is described at [4]. It is
>> proposed this approach is used to generate JSON for a
>> MapServer "homepage".
>> The generated JSON format can be seen at https://
>> demo.pygeoapi.io/api-catalog.json <https://
>> demo.pygeoapi.io/api-catalog.json>, with an extract below:
>> "linkset": [
>> "anchor": "https://demo.pygeoapi.io/master
>> <https://demo.pygeoapi.io/master>",
>> "service-desc": [
>> "href": "https://demo.pygeoapi.io/master/
>> openapi?f=json <https://demo.pygeoapi.io/master/
>> openapi?f=json>",
>> "title": "pygeoapi - latest GitHub 'master'
>> version (JSON)",
>> "type": "application/vnd.oai.openapi+json"
>> "service-doc": [
>> openapi?f=html <https://demo.pygeoapi.io/master/
>> openapi?f=html>",
>> version (HTML)",
>> "type": "text/html"
>> The spec allows for an additional "service-meta"
>> property "used to link to additional metadata about
>> the API,
>> and is primarily intended for machine consumption." I
>> think this can be used to add any additional
>> properties from Mapfiles
>> we'd need to generate a MapServer homepage.
>> "service-doc" isn't mandatory, so WxS service links
>> can ignore this. An example of the proposed JSON and
>> metadata is shown below:
>> "linkset": [
>> "anchor": "https://demo.mapserver.org/ <https://
>> demo.mapserver.org/>",
>> "service-desc": [
>> "href": "https://demo.mapserver.org/cgi-bin/
>> msautotest?
>> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>> <https://demo.mapserver.org/cgi-bin/msautotest?
>> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>> "title": "World WMS service",
>> "type": "text/xml"
>> "service-meta": {
>> "type": "wms",
>> "title": "WMS demo server for MapServer,
>> used in the msautotest suite",
>> "keywords": ["layers", "list"],
>> "mapfile": "msautotest.map",
>> Seth
>> [1] https://demo.pygeoapi.io/ <https://demo.pygeoapi.io/>
>> [2] https://github.com/geopython/demo.pygeoapi.io/
>> pull/60/files <https://github.com/geopython/
>> demo.pygeoapi.io/pull/60/files>
>> [3] https://datatracker.ietf.org/doc/draft-ietf-
>> httpapi-api-catalog/08/ <https://datatracker.ietf.org/
>> doc/draft-ietf-httpapi-api-catalog/08/>
>> [4] https://www.rfc-editor.org/rfc/rfc9264.html
>> <https://www.rfc-editor.org/rfc/rfc9264.html>
>> & https://mapserverstudio.net <https://
>> On Sun, Jan 19, 2025, at 5:10 PM, Tom Kralidis wrote:
>> Seth: thanks for this RFC. IETF has api-catalog
>> (draft, [1]) which I think would be a good
>> candidate for this RFC. This is also an item for
>> review in the OGC API - Records SWG [2].
>> Overall it looks pretty close to the RFC
>> proposal. We can consider using api-catalog as a
>> baseline and we can extend the JSON accordingly as
>> needed for anything specific to our needs.
>> Cheers
>> ..Tom
>> [1] https://datatracker.ietf.org/doc/draft-ietf-
>> httpapi-api-catalog <https://datatracker.ietf.org/
>> doc/draft-ietf-httpapi-api-catalog>
>> [2] https://github.com/opengeospatial/ogcapi-
>> records/issues/355 <https://github.com/
>> opengeospatial/ogcapi-records/issues/355>
>> On Sat, Jan 18, 2025 at 5:39 PM Seth G via
>> MapServer-dev <mapserver-dev at lists.osgeo.org
>> <mailto:mapserver-dev at lists.osgeo.org>> wrote:
>> Looking again at the landing page JSON at
>> https://demo.mapserver.org/cgi-bin/mapserv/
>> localdemo/ogcapi?f=json <https://
>> demo.mapserver.org/cgi-bin/mapserv/localdemo/
>> ogcapi?f=json> it is in the same format, so as
>> you suggested could simply be expanded with
>> links to WxS services, or even CGI generated
>> responses. This would also more easily allow
>> template reuse.
>> Seth
>> geographika.net/> & https://
>> On Sat, Jan 18, 2025, at 11:33 PM, Seth G via
>> > Hi Even,
>> > Thanks for your valuable feedback.
>> > The homepage would be a "superset" of all
>> available Mapfiles in a
>> > MapServer deployment, as listed in the
>> CONFIG file. Each individual
>> > Mapfile would still have its own OGC API
>> landing page, so the homepage
>> > is best described as a directory of all
>> landing pages.
>> > As most MapServer deployments will likely be
>> serving out a combination
>> > of WxS and new OGC API services for some
>> time to come, it will allow
>> > both types to be listed together (I'm
>> unaware of a OGC API spec that
>> > would cover this).
>> > In regard to the JSON used for links, I was
>> modelling it as closely as
>> > possible to OGC API conventions. Looking at
>> the pygeoapi demo home
>> > page, it provides a set of links in a common
>> format, so I'll likely
>> > switch to this format/approach:
>> > https://demo.pygeoapi.io/stable?f=json
>> <https://demo.pygeoapi.io/stable?f=json>
>> > A few of the "rel" values are defined as
>> below, and can be reused:
>> > alternate Provides an alternate
>> representation (e.g., HTML version of a
>> > resource).
>> > service-desc Links to the machine-readable
>> API description (e.g.,
>> > OpenAPI JSON).
>> > service-doc Links to the human-readable
>> API documentation (e.g.,
>> > OpenAPI HTML).
>> > conformance Lists the standards and
>> conformance classes supported by
>> > the API.
>> > I'll update the RFC with the above,
>> > Seth
>> > On Sat, Jan 18, 2025, at 12:39 PM, Even
>> Rouault wrote:
>> >> Seth,
>> >> Thanks for putting this together. I'm
>> wondering how much your proposal
>> >> relates/intersects with the concept of the
>> landing page of OGC API
>> >> services ? You mention some connection with
>> it, but it is not
>> >> immediately clear to me the exact nature
>> of the connection. Perhaps it
>> >> is just a matter of clarifying. I have put
>> zero thoughts in it, but it
>> >> would feel weird to invent a MapServer
>> specific thing, so I'm naively
>> >> wondering if we can't we just adopt the
>> landing page formalism (for the
>> >> JSON part), and potentially extend it by
>> exposing old WxS services as
>> >> well in the links as you suggest? I'm also
>> wondering if there's some
>> >> best practice used by other projects on how
>> to expose for things like
>> >> "href":
>> >> "https://demo.mapserver.org/cgi-bin/wms?
>> SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities <https://demo.mapserver.org/cgi-bin/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>",
>> >> "title": "GetCapabilities",
>> >> "type": "WMS"
>> >> so they can be interoperably consumed.
>> >> Even
>> >> Le 18/01/2025 à 09:11, Seth G via
>> MapServer-dev a écrit :
>> >>> Hi devs,
>> >>> I've drafted an RFC with an approach of
>> creating a MapServer homepage based on the
>> MAPs referenced in a mapserver.conf file. This
>> will allow MapServer installations to easily
>> advertise available services, dynamically.
>> >>> Text available in pull request at https://
>> pull/996 <https://github.com/MapServer/
>> MapServer-documentation/pull/996>
>> >>> Comments and thoughts appreciated,
>> >>> Thanks,
>> >>> Seth
>> >>> MapServer-dev mailing list
>> >>> MapServer-dev at lists.osgeo.org
>> <mailto:MapServer-dev at lists.osgeo.org>
>> >>> https://lists.osgeo.org/mailman/listinfo/
>> mapserver-dev <https://lists.osgeo.org/
>> mailman/listinfo/mapserver-dev>
>> >> http://www.spatialys.com <http://
>> www.spatialys.com/>
>> >> My software is free, but my time generally not.
>> >> Butcher of all kinds of standards, open or
>> closed formats. At the end,
>> >> this is just about bytes.
>> MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>> Daniel Morissette
>> Mapgears Inc
>> T: +1 418-696-5056 #201
>> Richard W. Greenwood
>> www.greenwoodmap.com <http://www.greenwoodmap.com/>
Daniel Morissette
Mapgears Inc
More information about the MapServer-dev
