Reprojection
Brent Fraser
bfraser at digitalscience.com
Thu Apr 29 22:37:04 EDT 1999
Rob,
Try putting the parameters in quotes:
PROJECTION
"proj=utm"
END
I was able to re-project in 2.3, but it did not
do datum shifts. Neither does 3.211 (there's
no code in Proj4 nor Mapserver to do datum
shifts).
If there's a big enough demand, I might be able
to find some source code for the Molodensky
datum transformation...
Brent Fraser
GeoAnalytic Inc.
1150 , 633 - 6th Avenue SW Calgary, AB T2P 2Y5
Tel: (403)213-2700 Fax: (403)213-2707
bfraser at geoanalytic.com
www.geoanalytic.com
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, April 29, 1999 6:34 PM
Subject: Reprojection
> Hi folks,
> does anybody have information regarding the use of PROJ.4 within the
> latest Mapserver (3.211).
> Trying to use the same technique as per Fornet 2.3 creates a lexical
> scanning error on the "=" signs. Looking at the code I suspect this is a
> problem in 3.211 map file parsing.
> PROJECTION
> proj=utm
> END
> Also, with 2.3 I was unable to make the thing reproject when all I
> wanted to do was a datum shift. Any clues on how to force it, and is
> this problem fixed in 3.2?
> Regards
> Rob Atkinson
> rob at socialchange.net
> Director Mob 0419
> 202 973
> Social Change Online Pty Ltd Ph +61
> (2)9557 6500
> http://online.socialchange.net Fax +61
> (2)9519 8940
