Reprojection
Rob Atkinson
rob at socialchange.net
Thu Apr 29 23:11:31 EDT 1999
Thats done the trick! Many thanks.
I'll have some interesting stuff to show the list soon - anybody else here
interested in the OpenGIS Web Mapping standards process?
Brent Fraser wrote:
> Rob,
> Try putting the parameters in quotes:
> PROJECTION
> "proj=utm"
> END
> I was able to re-project in 2.3, but it did not
> do datum shifts. Neither does 3.211 (there's
> no code in Proj4 nor Mapserver to do datum
> shifts).
> If there's a big enough demand, I might be able
> to find some source code for the Molodensky
> datum transformation...
> Brent Fraser
> GeoAnalytic Inc.
> 1150 , 633 - 6th Avenue SW Calgary, AB T2P 2Y5
> Tel: (403)213-2700 Fax: (403)213-2707
> bfraser at geoanalytic.com
> www.geoanalytic.com
> ----- Original Message -----
> From: Rob Atkinson <rob at socialchange.net>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, April 29, 1999 6:34 PM
> Subject: Reprojection
> > Hi folks,
> > does anybody have information regarding the use of PROJ.4 within the
> > latest Mapserver (3.211).
> > Trying to use the same technique as per Fornet 2.3 creates a lexical
> > scanning error on the "=" signs. Looking at the code I suspect this is a
> > problem in 3.211 map file parsing.
> > PROJECTION
> > proj=utm
> > END
> > Also, with 2.3 I was unable to make the thing reproject when all I
> > wanted to do was a datum shift. Any clues on how to force it, and is
> > this problem fixed in 3.2?
> > Regards
> > Rob Atkinson
> > Director Mob 0419
> > 202 973
> > Social Change Online Pty Ltd Ph +61
> > (2)9557 6500
> > http://online.socialchange.net Fax +61
> > (2)9519 8940
Rob Atkinson rob at socialchange.net
Director Mob 0419 202 973
Social Change Online Pty Ltd Ph +61 (2)9557 6500
http://online.socialchange.net Fax +61 (2)9519 8940
