Decimal degree units
Stephen Lime
steve.lime at dnr.state.mn.us
Thu Aug 26 23:46:54 EDT 1999
You're correct on the server issue. The mapscript piece should allow for use with mod_perl which may help significantly in some cases. I wish there was a single server API one could deal with. The more recent versions of the code have had a number of impediments to server API implementations removed so this should be much easier to do now.
Steve
<<< Rob Atkinson <rob at socialchange.net> 8/26 7:30p >>>
cshorte2 at csc.com wrote:
> > I'll try the PROJ.4 support, but I'm guessing that the performance hit will
> > kill me. Some of my maps have thousands of shapes on several layers.
> Rob Atkinson did some work on performance of PROJ.4 and reckoned it added 20% to
> 30% to the total processing time.
> Cameron.
FYI: This was on a shapefile about 20Mb in size, with highly detailed polys. Maybe
the fixed overheads of file IO are significant.
Having a memory resident server rather than a CGI would be the single biggest
performance boost I think.
Rob Atkinson rob at socialchange.net
Director Mob 0419 202 973
Social Change Online Pty Ltd Ph +61 (2)9557 6500
http://online.socialchange.net Fax +61 (2)9519 8940
