Decimal degree units
Brent Fraser
bfraser at digitalscience.com
Mon Aug 30 11:11:49 EDT 1999
Chris, (and all),
I haven't tried the shapefile indexing using shpindex
(my comments in the original email weer about the
tiling method supported by mapserver), but I'll have
a look at it this week...
Brent
----- Original Message -----
To: Brent Fraser <bfraser at digitalscience.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, August 28, 1999 2:47 AM
Subject: Re: Decimal degree units
> Brent, Hi... Along these lines, have you tried to index shapefiles
> under WinNT? I have never been able to get shpindex to work
> while compiled with MSC6.0. No errors or anything, but when I
> index a shapefile, that layer no longer displays at all.
> I was just wondering if you had actually gotten this to work.
> Thanks,
> -Chris (imap at chesapeake.net)
> Brent Fraser wrote:
> > I've made mapserv a memory resident component using Windows NT,
> > ActiveX and Active Server Pages. And I use PROJ4 to project on the
> > fly. But as Steve pointed out in a previous email, the most significant
> > tuning thing you can do is shapefile indexing. Tile the shapefiles (if
> > they aren't already) and make an index shapefile for them.
> > Also, selectively display shapefiles based on scale if you've got a
> > couple of different scales of data (eg 1:1m DCW, and Tiger).
> > Brent Fraser
> > From: Rob Atkinson <rob at socialchange.net>
> > To: <cshorte2 at csc.com>
> > Sent: Thursday, August 26, 1999 6:20 PM
> > > cshorte2 at csc.com wrote:
> > > > > I'll try the PROJ.4 support, but I'm guessing that the performance
hit
> > will
> > > > > kill me. Some of my maps have thousands of shapes on several
layers.
> > > > Rob Atkinson did some work on performance of PROJ.4 and reckoned it
> > added 20% to
> > > > 30% to the total processing time.
> > > > Cameron.
> > > FYI: This was on a shapefile about 20Mb in size, with highly detailed
> > polys. Maybe
> > > the fixed overheads of file IO are significant.
> > > Having a memory resident server rather than a CGI would be the single
> > biggest
> > > performance boost I think.
> > > Rob Atkinson
> > > Director Mob
0419
> > 202 973
> > > Social Change Online Pty Ltd Ph +61
> > (2)9557 6500
> > > http://online.socialchange.net Fax +61
> > (2)9519 8940
