Zooming on images
Doug Nebert
ddnebert at usgs.gov
Tue Sep 21 10:14:55 EDT 1999
Stephen Lime wrote:
> Um, er... Scale calculations with DD data are broken. That is, since
> x cellsize (no straight DD/in conversion) varies I didn't add the s
> upport to calculate some average scale even though it's just an
> approximation. I got some equations from the guys at Space Imaging
> and have added scale calculation support for DD units to the new
> version. With that version you'll be able to do exactly what you propose
> with the layer descriptions below.
> ** Note **
It is after all alCartesian coordinate system, and should be treated
as such. You don't want special rules for some but not all data!
In this vein, I expect that zoom or scale would be the same across
the map. Remember that all projections are approximations and
unless you are using a real equal area projection, area will vary
across a map. I really need to be able to determine the linear
transform of the window to coordinates so that the java map applet
can calculate lat-long coordinates from clicks in the frame. This
should apply to all coord ref systems, shouldn't it?
> The scale problem only effect the minscale/maxscale piece but
> you should be able to zoom in and out. (you'll have to pick an image
> to use). You might try commenting out the minscale/maxscale stuff
> and turning all rasters off except for 1 and see if that helps.
> Got a "get" URL I can play with?
http://130.11.52.178/cgi-bin/mapserv?mode=map&layer=elevation&mapext=-180+-90+180+90&map=/var/mapserver/global/global.map&mapsize=500+250
If I change the mapext, nothing changes. I need that. Zoom
won't cut it for the query interface I need. Should be able to
enter any window that is preferably 2x wide by 1x tall in degrees.
Just shows the full image.
Also, I am still unable to show a vector coverage on top of
the image. Is there a special call for order? It is layer named
boundary but it won't display. I can also not zoom on it whereas
the country layer (polygon) I can! So the problem seems to be
with both raster and line data. Puzzled.
check:
http://130.11.52.178/cgi-bin/mapserv?mode=map&layer=country&mapext=-126+47+-122+45&map=/var/mapserver/global/global.map&mapsize=500+250
http://130.11.52.178/cgi-bin/mapserv?mode=map&layer=boundary&mapext=-180+-90+180+90&map=/var/mapserver/global/global.map&mapsize=500+250
http://130.11.52.178/cgi-bin/mapserv?mode=map&layer=boundary&mapext=-126+47+-122+45&map=/var/mapserver/global/global.map&mapsize=500+250
> Steve
> Stephen Lime
> Internet Applications Analyst
> MIS Bureau - MN DNR
> (651) 297-2937
> steve.lime at dnr.state.mn.us
> >>> ddnebert <ddnebert at usgs.gov> 09/20 2:45 PM >>>
> I have now four nice TIF images that I would like to use as backdrop to
> other
> data. The files are as follows with wld files that let them render fine
> individually
> at full extent. If I try to set another extent in the GET request, I
> still see the
> whole world, rather than a zoomed in region.
> shdrela.tif 640 x 320 TIF
> shdrelb 2160 x 1080 TIF
> shdrelc 4800 x 2400 TIF
> shdreld 10800 x 5400 TIF
> So I have two problems:
> 1. How do I make the registration correct? I calculated the TFW files
> as attached.
> 2. Once I can view one of the files, I'd like to set them up as a
> cascade
> of a single theme, broken by MINSCALE and MAXSCALE values.
> Should the following work?
> LAYER
> NAME shdrelief
> TYPE RASTER
> STATUS ON
> DATA shdrela.tif
> MINSCALE 5000000
> OFFSITE 0
> END
> LAYER
> NAME shdrelief
> TYPE RASTER
> STATUS ON
> DATA shdrelb.tif
> MINSCALE 3000000
> MAXSCALE 5000000
> OFFSITE 0
> END
> LAYER
> NAME shdrelief
> TYPE RASTER
> STATUS ON
> DATA shdrelc.tif
> MINSCALE 1000000
> MAXSCALE 3000000
> OFFSITE 0
> END
> LAYER
> NAME shdrelief
> TYPE RASTER
> STATUS ON
> DATA shdreld.tif
> MAXSCALE 1000000
> OFFSITE 0
> END
Douglas D. Nebert
Clearinghouse Coordinator
FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
Pager Messaging: http://fgdclearhs.er.usgs.gov/dougmsg.html
