Funny units for jpeg images
    John Hockaday
    johnh at erin.gov.au
    Fri Aug 18 06:52:50 PDT 2000
This is probably a summary for this subject as I can now successfully
view greyscale jpegs and 8-bit colour tiffs using mapserv.
First of all thanks very much to Jason Maestri and Chris Stuber for
pointing me in the right direction to find the error.  Also thanks to
Mel VanderWal for pointing me to Todd Poston's arcview extension to
generate world files and finally to Steve and Aaron for considering the
future code aspects.
The problem was that I used XV to convert a colour jpeg to a greyscale
jpeg.  XV resized the image to suit my screen size and therefore its
pixel georeferencing was lost.  I solved this problem by loading the
jpeg image into ImageMagicks "display" X11 presentation tool and then
saving it as a greyscale jpeg.  ImageMagick did not resize the image to
fit the screen and therefore the pixel georeferencing was maintained.
The second problem was that my "imagine" tiff was 24-bit and did not
have a georeferenced world file.  The georeferencing was in the header
file of the original tiff file.  Again I used ImageMagick's "display"
tool to "quantize" the tiff file into a 256 colour (8-bit) image.  The
next problem was the tiff world file.  Todd Poston's Arcview extension
allowed me to generate this file and I was finally able to view the
colour tiff with mapserv.
I greatly appreciate each persons help.  It shows that the combination
of each little suggestion can solve a problem.  This is the most
responsive list on which I have been subscribed and I can see that it
is beneficial to many other people.  Keep up the good work.
Thanks again for all your help.
John Hockaday
> > From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
> I sort of agree. The ESRI naming standards are stupid with respect to
> world files. The .wld is now the ESRI standard and I see no real reason
> to support the old stuff. (.jpw and .tfw are already supported) We'll
likely
> be moving from the current raster engine to a new one that supports a
> much wider variety of formats soon.
> Supporting the .shp extension is a good idea. The non-extension filename
> is a hold over from the shapelib library for reading shapefiles. Since a
shapefile
> isn't a single file I suppose it made sense conceptually at the time.
Send the
> diffs if you've got 'em.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> <ender at titan.lab.csuchico.edu> 08/01/00 03:41AM >>>
> Steve, other developers:
>   This brings up one of those little things that I've wanted to fix but
> haven't gotten around to.  Mapserver really needs to follow the rules for
> reading world files.  The rules are: if the extention has three
> characters, the world file will be the first and last character of the
> extention followed by a 'w'.  For example: image.tif -> image.tfw,
> image.gif -> image.gfw, image.jpg -> image.jgw.
>   If the extention has more than three characters, the 'w' is appended to
> the complete extention: image.tiff -> image.tiffw, image.jpeg ->
> image.jpegw.
>   If the extention is missing, the 'w' is added to the filename: image ->
> imagew.
>   I think many of our new users problems stem from the non-standard file
> names Mapserver uses.
>   Another place where a change could be made is in the mapfile, when you
> are specifying the data for a shapefile base feature theme, the mapserver
> will not allow you to put the .shp extention on this file.  All other
data
> types allow the extention, except for the .shp.  This is very easy to
> compensate for, so I wonder if there is a reason for this being the way
it
> is...  If not, I will submit diffs to implement this change.
> -Aaron
> On Tue, 1 Aug 2000, Mel VanderWal wrote:
> > Hey all.
> > If you need to create world files in ArcView, Todd Poston recently
posted a
good
> > extension (and the source code) on the ESRI ArcScripts site
(http://gis.esri.com/arcscripts/details.cfm?CFGRIDKEY=B718A422-5E5A-11D4-9432005
08B0CB419).
> > I only tested it a little, but Todd knows what he's doing, so it's
probably
solid.
> > For MapServer users, use the .apr instead of the extension, so you can
change one
> > line in the script QDIR.View.WriteWorldFile.Click.  Then georeference
your
images
> > in that apr.
> > Change:
> > theFN =
FileName.Merge(theISrc.GetSrcName.GetFileName.ReturnDir.AsString,theISrc.GetSrcN
ame.GetFileName.GetBaseName
> > + "w")
> > To:
> > theFN = theISrc.GetSrcName.GetFileName
> > theFN.SetExtension("tfw")
> > or else the world file will get a .tifw extension instead of a .tfw
extension,
> > which is OK in ArcView, but MapServer won't recognize it.  One ArcView
world
file
> > convention is simply to add a "w" to the image's file extension, so
that's
the way
> > many world files are named.  It's probably minor for most MapServer
users,
but I
> > spent awhile figuring out why an image wouldn't georeference.  (Steve:
Maybe
to
> > make using the same data a little easier... - wishlist item?)
> > imap at chesapeake.net wrote:
> > > Hello, This isnt exactly right...  THe worldfile X/Y is the upper
left
> > > pixel, not bottom right.  I have found that matching projections is
not an
> > > exact science.  Sometime you need to adjust the X/Y and map units to
stretch
> > > the raster to get a tight fit.
> > > I have done a couple of these..  You have to begin with PROJ and
knowing
> > > the precise projection and central meridian.  That should get it
close,
> > > then you can tweak the map units in the X/Y to shore up the edges.
> > > Also, keep in mind that rasters may never match their vector
counterparts,
> > > due to basemap mismatch and thinning etc.
> > > It very well could be, that your JPG is a different projection???
> > > I have several *very* nice raster maps here (Mountain High Maps) that
I am
> > > unable
> > > to match the base projection with anything in PROJ.  Since there is
no
> > > metadata
> > > for the images, it requires much guesswork.
> > > Regards,
> > > Chris Stuber (mapsurfer)
> > > Silicon Mapping Solutions, Inc
> > > Jason Maestri wrote:
> > > > John,
> > > > I am not sure why your data don't line up. The world file is okay,
the
only
> > > > coordinates that are specified in the esri type world
> > > > files are the X and Y of the bottom right corner.  They seem to be
really
> > > > close to what you think they should be, so I'd imagine
> > > > that the world file is not your problem.  Mapserver doen't care
what
> > > > projection your data are in, so there isn't any place to
> > > > specify projections.  I'd use arcview or grass or something to make
sure
they
> > > > really do line up, and further explore the problem.
> > > > --Jason
> > > > John Hockaday wrote:
> > > > > Hi,
> > > > > I am trying to get a jpeg to load as a background image with
vector
> > > > > data on top of it.  Both are in geographical coodinates however,
when
I
> > > > > load one on top of the other they seem to be in different
projections.
> > > > > The world file for the jpeg looks like this:
> > > > >             0.000450
> > > > > 0
> > > > > 0
> > > > >            -0.000450
> > > > > 150.000914
> > > > > -33.998391
> > > > > The image is supposed to be from TL(150, -34) to BR(151.5, -35).
That
> > > > > is 1.5 degrees by 1 degree with the top left corner at 150
degrees
long
> > > > > and -34 degrees lat.
> > > > > Am I missing out on specifying a decimal degrees unit for my
layers in
> > > > > the map file?  The map file is attached.
> > > > > I would be greatfull for any information if someone else has used
> > > > > georeferenced jpegs and vector shapefiles in a geographic
coordinate
> > > > > system.
> > > > > Thanks in advance.
> > > > > John Hockaday
> > > > > # Start of map file
> > > > > NAME DEMO
> > > > > STATUS ON
> > > > > SIZE 600 600
> > > > > SHADESET /opt/contrib/src/ms_3.3.010/symbols/shade.sym
> > > > > MARKERSET /opt/contrib/src/ms_3.3.010/symbols/marker.sym
> > > > > LINESET /opt/contrib/src/ms_3.3.010/symbols/line.sym
> > > > > EXTENT 149 -35 152 -32
> > > > > UNITS dd
> > > > > SHAPEPATH "/info/cgi-data/atlas/fornet/"
> > > > > IMAGECOLOR 255 255 255
> > > > > #LABELOVERLAP FALSE
> > > > > # Start of web interface definition
> > > > > WEB
> > > > >   #HEADER demo_header.html
> > > > >   TEMPLATE demo.html
> > > > >   #MINSCALE 1000
> > > > >   #MAXSCALE 1550000
> > > > > END
> > > > > # Start of reference map
> > > > > #REFERENCE
> > > > >   #IMAGE graphics/reference_base.gif
> > > > >   #EXTENT 481093.000000 4969319.036682 502271.000000
4997508.3073184
> > > > >   #STATUS ON
> > > > >   #COLOR -1 -1 -1
> > > > >   #OUTLINECOLOR 255 0 0
> > > > > #END
> > > > > # Start of legend
> > > > > LEGEND
> > > > >   KEYSIZE 18 12
> > > > >   LABEL
> > > > >     TYPE BITMAP
> > > > >     SIZE MEDIUM
> > > > >     COLOR 0 0 89
> > > > >   END
> > > > >   STATUS ON
> > > > > END
> > > > > # Start of scalebar
> > > > > SCALEBAR
> > > > >   LABEL
> > > > >     COLOR 0 0 0
> > > > >     SIZE SMALL
> > > > >   END
> > > > >   SIZE 350 5
> > > > >   COLOR 255 255 255
> > > > >   BACKGROUNDCOLOR 0 0 0
> > > > >   OUTLINECOLOR 0 0 0
> > > > >   UNITS kilometers
> > > > >   INTERVALS 5
> > > > >   STATUS ON
> > > > > END
> > > > > # Start of layer definitions
> > > > > LAYER
> > > > >   NAME coast
> > > > >   TYPE POLYGON
> > > > >   STATUS DEFAULT
> > > > >   DATA coast
> > > > >   CLASS
> > > > >     SYMBOL 0
> > > > >     OUTLINECOLOR 0 0 0
> > > > >     COLOR 248 248 95
> > > > >   END
> > > > > END
> > > > > LAYER
> > > > >   NAME si5609g
> > > > >   TYPE RASTER
> > > > >   STATUS ON
> > > > >   OFFSITE 0
> > > > > END
> > > > > LAYER
> > > > >   NAME cocos
> > > > >   TYPE RASTER
> > > > >   STATUS ON
> > > > >   DATA cocos.tif
> > > > >   OFFSITE 0
> > > > > END
> > > > > LAYER
> > > > >   NAME soils
> > > > >   TYPE POLYGON
> > > > >   STATUS ON
> > > > >   DATA soils
> > > > >   TOLERANCE 3
> > > > >   CLASSITEM "symbol"
> > > > >   CLASS
> > > > >     NAME "Classification by Symbol"
> > > > >     EXPRESSION "7"
> > > > >     COLOR 204 096 085
> > > > >     BACKGROUNDCOLOR 32 201 201
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "27"
> > > > >     COLOR 255 255 000
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "33"
> > > > >     COLOR 204 191 085
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "37"
> > > > >     COLOR 234 223 085
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "52"
> > > > >     COLOR 204 223 170
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "62"
> > > > >     COLOR 204 159 085
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "98"
> > > > >     COLOR 255 255 170
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "146"
> > > > >     COLOR 153 159 085
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "158"
> > > > >     COLOR 204 159 085
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "177"
> > > > >     COLOR 153 064 000
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "200"
> > > > >     COLOR 153 128 000
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "202"
> > > > >     COLOR 102 159 170
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "212"
> > > > >     COLOR 153 128 000
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   CLASS
> > > > >     EXPRESSION "216"
> > > > >     COLOR 153 159 000
> > > > >     OUTLINECOLOR 0 0 0
> > > > >   END
> > > > >   #QUERYITEM symbol
> > > > >   QUERY
> > > > >     #EXPRESSION "216"
> > > > >     TEMPLATE demo.html
> > > > >     #JOIN "data/lakejoin.dbf" islake "type"
> > > > >   END
> > > > >   #QUERY
> > > > >   #EXPRESSION "^-"
> > > > >     #TEMPLATE land.html
> > > > >   #END
> > > > > END # Layer
> > > > > LAYER
> > > > >   NAME rne12030
> > > > >   TYPE POLYGON
> > > > >   STATUS ON
> > > > >   DATA rne12030
> > > > >   TOLERANCE 5
> > > > >   CLASS
> > > > >     NAME "rne12030"
> > > > >     COLOR 49 117 185
> > > > >   END
> > > > >   QUERY
> > > > >     TEMPLATE /info/cgi-data/atlas/fornet/rne12030.html
> > > > >   END
> > > > > END # Layer
> > > > > LAYER
> > > > >   NAME rail
> > > > >   TYPE LINE
> > > > >   STATUS ON
> > > > >   DATA rail
> > > > >   SYMBOLSCALE 4
> > > > >   CLASS
> > > > >     NAME "rail"
> > > > >     COLOR 212 212 212
> > > > >     SYMBOL 13
> > > > >     SIZE 2
> > > > >     MAXSIZE 4
> > > > >   END
> > > > >   QUERY
> > > > >     TEMPLATE /info/cgi-data/atlas/fornet/rail.html
> > > > >   END
> > > > > END # Layer
> > > > > #LAYER
> > > > > #  NAME primary_roads
> > > > > #  TYPE LINE
> > > > > #  STATUS OFF
> > > > > #  DATA primary
> > > > > #  SYMBOLSCALE 24000
> > > > > #  CLASS
> > > > > #    NAME "Primary Roads"
> > > > > #    COLOR 128 128 128
> > > > > #    SYMBOL 13
> > > > > #    SIZE 3
> > > > > #    MAXSIZE 5
> > > > > #  END
> > > > > #END # Layer
> > > > > #LAYER
> > > > > #  NAME runways
> > > > > #  TYPE LINE
> > > > > #  STATUS OFF
> > > > > #  DATA runways
> > > > > #  CLASS
> > > > > #    COLOR 30 94 30
> > > > > #    NAME "Airport Runways"
> > > > > #  END
> > > > > #END # Layer
> > > > > LAYER
> > > > >   NAME "points"
> > > > >   TYPE ANNOTATION
> > > > >   STATUS ON
> > > > >   MAXSCALE 6555555
> > > > >   DATA "points"
> > > > >   TOLERANCE 10
> > > > >   LABELITEM "Place_name"
> > > > >   CLASS
> > > > >     SIZE 8
> > > > >     COLOR 255 0 0
> > > > >     SYMBOL 6
> > > > >     LABEL
> > > > >       BACKGROUNDCOLOR 200 255 255
> > > > >       COLOR 30 94 94
> > > > >       TYPE BITMAP
> > > > >       #JUSTIFY CENTER
> > > > >       SIZE GIANT
> > > > >       POSITION AUTO
> > > > >       WRAP " "
> > > > >     END # Label
> > > > >   END # Class
> > > > >   QUERY
> > > > >     TEMPLATE /info/cgi-data/atlas/fornet/points.html
> > > > >   END # Query
> > > > > END # Layer
> > > > > END # Map File
> > Mel VanderWal
> > GIS Programmer / Manager
> > GAIA Consultants Inc.
> > Suite 306, 822-11th Avenue SW
> > Calgary, Alberta
> > Canada
> > T2R 0E5
> > Phone: (403) 571-7216
> > Fax: (403) 571-7211
> > www.gaiaenv.com
> > vanderwalm at gaiaenv.com
More information about the MapServer-users
