php3-expression and zoom
Christian
christian at gottschling.net
Wed Aug 30 11:22:47 PDT 2000
this answer was damn fast! Many thanks, I try it tomorrow when I am back in
the office.
This helps a lot!
Has there anybody an example for the zooming-buttons, too? I haven't found
out from the gmap-example.
Can I even set a dynamic label to the regions selected by "expression"?
> Here is an example that dynamically creates classes
>on a certain layer (assumes here that $gpoMap is the
>map object and there is a layer called classified in
>the .map file) :
>$poLayer = $gpoMap->getlayerbyname("classified");
>$poLayer->set("classitem", "VW");
>$nColorId = $gpoMap->addColor(255, 0, 0);
>$poClass = ms_newClassObj($poLayer);
>$poClass->set("color", $nColorId);
>$poClass->setExpression("069");
What is the maximum number of classes and what is the practical maximum so
that the map is served in time?
I like to run this within a loop and in the worst case I would have more
than 5000, (all prefixes of germany).
Christian
christian
More information about the MapServer-users
