MapServer and SDE
John Hockaday
johnh at erin.gov.au
Sun Dec 17 19:13:22 EST 2000
Hi Gernot,
I'm not familiar with Windows NT so I can't answer your question with
confidence. However, having said that, I do know that you will have to
compile mapserv with the SDE option. Otherwise I think that it will
not work. You will also need to make sure that your Oracle client
software is available on your mapserv server so that it knows how to
connect to the Oracle server. You will need to do this before you
compile mapserv.
I hope that this helps. Steve Lime will definitely know more about it
but I expect that he is very busy an relies on other users replying if
they know the answer. I hope that someone will correct me if they know
that I have said something wrong.
Johnh
> From: "Gernot Ruecker" <gruecker at zebris-geoconsult.de>
> To: "John Hockaday" <johnh at erin.gov.au>, <mapserver-users at lists.gis.umn.edu>
> Subject: Re: MapServer and SDE
> Date: Sun, 17 Dec 2000 17:51:52 +0100
> Mime-Version: 1.0
> Content-Transfer-Encoding: 8bit
> X-Priority: 3
> X-MSMail-Priority: Normal
> X-MIMEOLE: Produced By Microsoft MimeOLE V5.00.2314.1300
> Hi list,
> I've got one more question concerning ArcSDE and Mapserver. I'm trying to
> use Mapserver with ArcSDE layers and get the error message:
> "msDrawSDELayer(): General error message. SDE support is not available. " I
> am working on NT and Oracle using the windows binaries. Does this mean that
> SDE support is not available with them and I have to rebuild the exe
> including SDE-support or simply that my SDE is not responding correctly or I
> commited some other error? I am using Mapserver 3.3.011.
> Thanks a lot for your help.
> Gernot
> -----Ursprüngliche Nachricht-----
> Von: John Hockaday <johnh at erin.gov.au>
> An: <mapserver-users at lists.gis.umn.edu>
> Gesendet: Montag, 11. Dezember 2000 01:30
> Betreff: Re: MapServer and SDE
> > Hi Chris,
> > I tried to use mapserv with SDE 3.0.2 but I had no sucess. I did
> > however manage to compile it using SDE 8.0.2 and Oracle 8.i.
> > Most things work except EXPRESSIONS, LABELS and ANNOTATION though I am
> > only using mapserv version 3.3.011. Version 3.3.012 may have fixed
> > these problems.
> > Johnh
> > > Date: Sat, 09 Dec 2000 14:25:25 -0500
> > > From: Chris Barber <barberc at msu.edu>
> > > X-Accept-Language: en
> > > MIME-Version: 1.0
> > > To: mapserver-users at lists.gis.umn.edu
> > > Subject: MapServer and SDE
> > > Content-Transfer-Encoding: 7bit
> > > Howdy.
> > > Has anyone successfully built MapServer with support for ESRI's SDE
> 3.0.2
> > > for Oracle on an IRIX system?? 'make' bails out on me when building the
> > > 'shp2img' binary. Some additional info that might be useful in helping
> > > to point me in the right direction (hopefully):
> > > IRIX: 6.5.9m
> > > Oracle: 8.0.5
> > > SDE: 3.0.2
> > > gcc: 2.95.2
> > > My 'configure': "./configure --with-sde=/net/gis/sde/sdeexe302"
> > > (bare bones for now til I can make SDE work)
> > > On a unrelated note, anybody know if the PHP MapScript module can
> > > be compiled/used with PHP4?
> > > TIA,
> > > \Chris
> > > __________________________________________________
> > > Christopher P. Barber
> > > GIS/RS Specialist, Unix Systems Management
> > > Basic Science & Remote Sensing Initiative
> > > Dept. of Geography, Michigan State Univ.
> > > http://bsrsi.msu.edu
> > > Rm. 210 Manly Miles Bldg.
> > > 1405 S. Harrison Road
> > > East Lansing, MI 48823-5243
> > > 517.432.1883 Phone
> > > 517.353.2932 FAX
> > > barberc at msu.edu
