Optimizing Data Base for GeoData
John Millard
millarj at lib.muohio.edu
Tue May 23 06:34:59 PDT 2000
Chris,
You might look into the new PostgreSQL 7.0. I haven't used it yet, but
one of the changes listed on their announcement is:
"Optimizer Overhaul:
Continuing on work started a year ago, the optimizer has been
overhauled, allowing improved query execution and better
performance with less memory usage. "
The rest of the announcment can be found here:
http://www.postgresql.org/news.html
Might be helpful,
John
_________________________________________________________
John Millard
Information Services Librarian
Miami University, Oxford, OH 45056-1878
More Information: http://staff.lib.muohio.edu/~millarj/
gnupg public key: http://staff.lib.muohio.edu/~millarj/gpg/
> Howdy,
> This might be slightly off topic, but I've presently got a
> web-based mapping/reporting system that I've got up-and-running. I'm
> using the MapScript perl module and am talking to a Postgres Data Base
> with all the geodata on it. The layout of the data base is similar to an
> ESRI shapefile (I can be more detailed if you want).
> The main problem I'm having is data base performance. I've tinkered with
> the data base and have added enough indexes to make a considerable
> difference in performance. I've also limited the number of layers I'm
> drawing when my scale is above a certain point.
> It looks like what we'll have to do is simply purchase faster
> hardware. When I moved the data base from a Solaris x86 box (either a
> P-233 or an AMD K6-300) to a Linux Box (450MHz K6-III) I got close to a
> 50% improvement and that's with the Linux box running the web server, perl
> script, AND Postgres. If anyone has any additional recommendations as far
> as laying out the data base is concerned, please let me know.
> Also, anyone have any experience with Oracle Spatial? Is it worth the $$?
> Finally, if anyone wishes to use PostgreSQL as a low-cost solution for
> writing a GIS type application, I can heartily recommend it. It comes
> with some nice geographic data types and functions. It also plays well
> with Perl.
> Chris Fuhrman | Twenty First Century Communications
> cfuhrman at tfcci.com | Software Engineer
> (W) 614-442-1215 x271 |
> (F) 614-442-5662 | PGP/GPG Public Key Available on Request
More information about the MapServer-users
