OpenGIS Simple Features and other Specs
Doug Nebert
ddnebert at usgs.gov
Tue May 23 07:36:32 PDT 2000
Robert Chavez wrote:
> Doug, could you supply a link to the OpenGIS access model? I haven't been
> able to locate it. Thanks.
See: http://www.opengis.org/techno/specs.htm#implementation
Both Oracle 8i Spatial and SDE (and others) can set up alternate access
via a configuration switch. OGC Conformance testing has been arduous but
seems to be getting easier with the suggestion of self-test
certification in order to really wear the OGC "label". This means there
may be untested but compatible implementations of Simple Features
(SF-SQL) out there. It would be nice to see someone make PostgreSQL be a
compatible SF-SQL solution!
Doug.
> Rob Chavez
> Programmer
> The Perseus Project
Douglas D. Nebert
Clearinghouse Coordinator
FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
Pager Messaging: http://clearinghouse3.fgdc.gov/dougmsg.html
More information about the MapServer-users
