[mapserver-users] PHP4.0.5?
Daniel Morissette
morissette at dmsolutions.ca
Fri Jun 1 09:02:12 EDT 2001
Also note that the php4.0.4_mapscript_dll-20010108.zip that you
downloaded was compiled with php4.0.4 and is likely not going to work
with php 4.0.5. We'll try to make a DLL for php 4.0.5 available next
week.
Daniel
Stepan Kafka wrote:
> The script attempts load the old version of mapscript dll library named
> php3_mapscript.dll. The library name is php_mapscript.dll now. Please,
> rewrite it in your source code (dl() command) or PHP configuration file.
> Stepan Kafka
> > -----Pùvodní zpráva-----
> > Od: owner-mapserver-users at lists.gis.umn.edu
> > [mailto:owner-mapserver-users at lists.gis.umn.edu]za uivatele Hankley,
> > Chip
> > Odesláno: 31. kvìtna 2001 21:36
> > Komu: MapServer List (E-mail)
> > Pøedmìt: [mapserver-users] PHP4.0.5?
> > I'm trying to get PHP configured on my machine.
> > I downloaded 4.0.5 and installed on PWS. Works fine.
> > I downloaded the php_mapscript.dll (php4.0.4_mapscript_dll-20010108.zip)
> > from the web site, and placed the dll in my C:\php\ directory.
> > I've downloaded the 3.3 and 3.4 source to obtain the
> > phpinfo_mapscritpt.phtml file.
> > Here's by problem...
> > When I try to load the php file, I get the following error:
> > Warning: Unable to load dynamic library 'C:\php/php3_mapscript.dll' - The
> > specified module could not be found. in
> > C:\Inetpub\wwwroot\PHP_tests\MapScript\phpinfo_mapscript.php on line 17
> > The rest of the page loads.
> > I've tried putting the *.dll in the same directory as the *.php file, the
> > cgi-bin dirctory, and the c:\php directory. I've also tried changing the
> > php.ini files extension_dir line to c:\php\. None of this seems to work.
> > Any ideas on what I'm doing wrong?
> > Chip
> > Chip Hankley, GIS Coordinator
> > Graef, Anhalt, Schloemer & Associates, Inc.
> > 5126 West Terrace Drive
> > Madison, Wisconsin 53718-8343
> > Telephone: (608) 245-1969
> > FAX: (608) 242-0787
> > http://www.gasai.com/
> > ChipHankley at GASAI.com
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
