[mapserver-users] PHP4.0.5?
Hankley, Chip
Chip.Hankley at GASAI.Com
Fri Jun 1 12:04:27 EDT 2001
OK, for the sake of the archive, here's an update based on everyone's
suggestions.
Bottom line, based on what Daniel said, is that I think the
php_mapscript.dll I'm using (which was compiled under 4.0.4) is the culprit,
and will not work under 4.0.5.
Here's what I've tried:
* editing the *.ini file to specify the location of the mapscript extension.
* changing the php tags in the sample file to call the correct dll.
* verifying that php is functioning (with a simple php files from David
Armstrong):
Today is <? print strftime("%m/%d/%Y"); ?>
* upgrading to mapserver 3.4
None of these worked, I still get the error:
Warning: Unable to load dynamic library
'C:\php\extensions/php_mapscript.dll' - The specified procedure could not be
found. in C:\Inetpub\wwwroot\PHP_tests\MapScript\phpinfo_mapscript.php on
line 17
Thanks!
Chip Hankley
