[mapserver-users] ESRI SDE and Linux
Ballard,Lowell
LBallard at YesVirginia.org
Wed Jun 13 10:49:15 EDT 2001
Things seem to be working fine on Redhat 7.0 on Intel. I'm using the 8.1
SDE client libraries talking to SDE with Oracle 8.1.6 on a SUN E4500 running
Solaris 7.
Just as a quick test I looked at the response of 2 layers of the same data
(1 local shapefile and one remote in SDE). This first test used a very
small data set (~1000 polys). The response was slower using SDE (about 1
second for local file and 2 seconds for remote SDE Layer).
I then tried I very large SDE contour layer (~1.3 million lines). I was
amazed. The line SDE layer displayed very rapidly (1-2 seconds depending on
# of features to be drawn). I didn't try to use the file-based data (i.e.,
coverage) so I don't have any comparisons for that but, based on my
experience with medium-sized shape files, SDE would smoke it. It's composed
of 3 coverages which are about 3.6GB total in size. I might try to crank
them into a single shapefile if I have time but...ArcInfo (32bit app)
doesn't like the big files-- that's why it's in 3 coverages currently.
The results were very promising. For CPU Utilization I was seeing a max of
about 50% CPU usage for the 1 second or so it took to draw the SDE Layer
when the amount of features being drawn was intense (contours for highly
mountainous regions zoomed out probably too far). Once I zoomed in on the
data set to a more reasonable viewing extent CPU utilization dropped
significantly (4-8% for about 1 second or less).
The web server is a pitiful Pentium III 500 MHz, 256 MB RAM, Dell Optiplex
running through 100mbs across 2 100mbs switches on the network then into a
GB switch to a GB interface on the SUN box. SDE is running in RAID 5 on SUN
StorEdge disk array (dual fiber connected to E4500) using Fibre-Channel
drives at 10k rpms.
Mapserver was built from the Nightly-build using this configure line:
./configure --with-sde-version=81 --with-sde=../sdeexe81/
--with-gd=/usr/local/src/gd-1.8.4
Here's the Layer line:
LAYER
NAME contours
CONNECTION "matoaka,esri_sde,gisdb,data,<PASSWORD>"
CONNECTIONTYPE sde
STATUS ON
DATA "contours_10m,shape"
TYPE LINE
MAXSCALE 20000
LABELMAXSCALE 10000
LABELITEM "contour"
HEADER contour.html
CLASS
NAME "Contours"
COLOR 200 36 43
TEMPLATE contour.html
LABEL
SIZE 8
MINSIZE 2
MAXSIZE 8
COLOR 200 36 43
BACKGROUNDCOLOR 245 240 219
MINFEATURESIZE auto
MINDISTANCE 50
TYPE TRUETYPE
POSITION lr
FONT tahoma
ANTIALIAS
BUFFER 1
END
END
END
This map service is not publicly accessible yet but will be soon on the
address below.
Lowell Ballard
Unix/Database Administrator
Virginia Economic Development Partnership
901 E. Byrd St., Richmond, Va. 23218
http://gis.vedp.org
-----Original Message-----
From: Robert Aldridge [mailto:bamarob55 at yahoo.com]
Sent: Wednesday, June 06, 2001 10:17 AM
To: Stephen Lime; MapServer_Users
Subject: Re: [mapserver-users] ESRI SDE and Linux
Steve,
I downloaded the nightly build this morning. I
configured it with:
--with-gd=../gd-1.8.4 --with-php=../php-4.0.5
--with-ttf=../freetype-2.0.1 --without-jpeg
--without-eppl
Everything appears to go fine. I do a make and once
again everything appears OK. I then copy the mapserv
binary to my cgi-bin directory and it doesn't work. I
kept my old binary around and it works fine. The only
difference between the two is the
--with-sde-version=81.
This is a Mandrake 7.0 system that has the SDE client
installed.
Any ideas?
Thanks,
Robert Aldridge
--- Stephen Lime <steve.lime at dnr.state.mn.us> wrote:
> Ok, I just committed changes that allow you to:
> - set the SDE version you want to compile against
> using the configure option --with-sde-version=xx
> where the version number is 80, 81 or whatever
> - compile on Linux against the SDE 8.1 client
> libraries
> I've compiled things on Solaris 2.6 and Redhat 6.2.
> I've not tested the code on Linux, just Solaris.
> I'll let you folks give it a shot.
> Anyway, nab the CVS version or the latest nightly to
> get at this new code.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
