[mapserver-users] ESRI SDE and Linux
Robert Aldridge
bamarob55 at yahoo.com
Wed Jun 6 10:17:05 EDT 2001
Steve,
I downloaded the nightly build this morning. I
configured it with:
./configure --with-sde-version=81
--with-gd=../gd-1.8.4 --with-php=../php-4.0.5
--with-ttf=../freetype-2.0.1 --without-jpeg
--without-eppl
Everything appears to go fine. I do a make and once
again everything appears OK. I then copy the mapserv
binary to my cgi-bin directory and it doesn't work. I
kept my old binary around and it works fine. The only
difference between the two is the
--with-sde-version=81.
This is a Mandrake 7.0 system that has the SDE client
installed.
Any ideas?
Thanks,
Robert Aldridge
--- Stephen Lime <steve.lime at dnr.state.mn.us> wrote:
> Ok, I just committed changes that allow you to:
> - set the SDE version you want to compile against
> using the configure option --with-sde-version=xx
> where the version number is 80, 81 or whatever
> - compile on Linux against the SDE 8.1 client
> libraries
> I've compiled things on Solaris 2.6 and Redhat 6.2.
> I've not tested the code on Linux, just Solaris.
> I'll let you folks give it a shot.
> Anyway, nab the CVS version or the latest nightly to
> get at this new code.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
