[mapserver-users] Expressions & SDE Layer -- More Info
Robert Aldridge
bamarob55 at yahoo.com
Thu Jun 14 11:43:30 EDT 2001
I tried the same thing on a hydrology layer that has a
"hydtype" item that is defined as a LONG INTEGER and
it worked perfectly.
--- Robert Aldridge <bamarob55 at yahoo.com> wrote:
> Date: Thu, 14 Jun 2001 08:13:24 -0700 (PDT)
> From: Robert Aldridge <bamarob55 at yahoo.com>
> Subject: Expressions & SDE Layer
> To: MapServer_Users
> <mapserver-users at lists.gis.umn.edu>
> Hello all,
> I have a layer in my map file defined as follows:
> LAYER
> NAME "Roads"
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE sde
> CONNECTION "comtrac,esri_sde,ArcInfo,sde,passwd"
> DATA "sde.roads,shape"
> CLASSITEM "roadtype"
> CLASS
> EXPRESSION /1/
> SYMBOL 1
> SIZE 1
> COLOR 255 0 0
> END
> CLASS
> EXPRESSION /2/
> SYMBOL 1
> SIZE 1
> COLOR 0 0 0
> END
> END
> Drawing the layer works fine without the
> expressions.
> The "roadtype" item is defined as a SMALLINT in my
> database. I get the following error with the above
> layer definition:
> sdeGetRecord(): SDE error. SE_stream_get_integer():
> Wrong column type. (-114)
> Changing the CLASSITEM to "cfcc" (which is a string
> item) and using "A41" and "A31" in the two
> expressions
> works fine.
> I'm wondering if this might be a bug because it is
> errorring out on SE_stream_get_integer when the item
> type is smallint.
> Any ideas?
> Thanks,
> Robert Aldridge
> __________________________________________________
> Do You Yahoo!?
> Get personalized email addresses from Yahoo! Mail -
> only $35
> a year! http://personal.mail.yahoo.com/
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
