[mapserver-users] Regular Expressions Question
Tim McGuire
tim.mcguire at dnr.state.mn.us
Thu Jun 14 15:10:19 EDT 2001
/[^a]/ will match anything that is not an 'a'
so it will return a match for 'Bubba' because there are characters there that are not 'a'
you could do /[^b-zA-B0-9 ]/
and that would not match any string with an 'a' (except if there were '@#$%' or something)
HTH
Tim McGuire
>>> Daniel Morissette <morissette at dmsolutions.ca> 06/14/01 09:27AM >>>
"Andries J. Algera" wrote:
> I would try to do something like this: /[^a]/
Thanks for all the replies... I tried using
EXPRESSION /[^a]/
but it doesn't work... it still matches fields that contain an 'a'. The
'man regex' on my test system (RH6.2) does mention the [^...]
'non-matching list' operator so it should support it but it doesn't
work.
Has anyone ever been able to use the [^...] operator with MapServer
REGEX? Perhaps it's just the way the above expression is built that's
not correct?
P.S. I also tried /[^a]*/ and /[^a]+/ just in case but it made no
difference.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
