[mapserver-users] accessing GD functions
Daniel Morissette
morissette at dmsolutions.ca
Tue Jun 19 10:57:18 EDT 2001
Vincent Jansen wrote:
> I have Mapserver compiled with GD 1.2 up and running in a Solaris/Apache/PHP
> environment.
> Now I wish to access PHP GD functions, but I don't know how to do this.
> Can anyone help get started ?
MapServer/MapScript uses GD to render the maps but it doesn't give you
access to PHP's GD functions.
To use PHP GD functions, you would need a PHP compiled with GD in, or
get a PHP_GD extension somewhere. On Unix, I guess the easiest is to
recompile PHP with the --with-gd=PATH switch then have a look at the
docs at http://www.php.net/manual/en/ref.image.php
Note that if you want to use MapScript with a PHP that has GD compiled
in then you should make sure both use the exact same version of the GD
library otherwise you might notice odd behaviors or even crashes.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
