[mapserver-users] SDE queries
Ballard,Lowell
LBallard at YesVirginia.org
Wed Jun 20 06:43:46 PDT 2001
RH 7.0
SDE libs 8.1 RH
SDE 8.0.2 Server SUN Solaris
MS 3.5 nightly 6/19/01
I've been experiencing strange behavior when nquerying (haven't been playing
with mode=query at all) SDE layers.
This is the site:
http://gis.vedp.org/test_map_sde <http://gis.vedp.org/test_map_sde>
by default when you initialize the map three layers are on:
County (shapefile)
Sites (SDE Layer poly)
Contours (SDE Layer line)
1. If I turn off all layers except sites I get Apache errors:
[Wed Jun 20 08:43:22 2001] [error] [client 172.16.10.76] Premature end of
script headers: /usr/local/apache/cgi-bin/mapservsde
Things work fine if I switch from SDE to a shapefile
2. If I leave the county shapefile turned on and try to query
sites/counties the results are inconsistent. On some site queries things
work fine and I get results for both the sites and the counties returned:
here: starting to return query
processing demo_header.html
processing sites_header.html
processing sites.html
processing county_header.html
processing county.html
processing demo_footer.html
processing vedp.html
On other site queries I only get the site header returned:
3. If I turn on the contour layer (SDE) and query the contour
sometimes I get a hit other times not. I almost always get a blank contour
record returned first if I do get a hit. You will need to query several
contours until you get a hit.
Contour
[CONTOUR]
Contour
50
It also places the results above my navigation bar (which is created using
mod_layout and called from the apache config file). I've never seen this
behavior in other queries.
4. Buildings is also an SDE layer and it behaves oddly as well.
See .map file attached
Lowell Ballard
Unix/Database Administrator
Virginia Economic Development Partnership
901 E. Byrd St., Richmond, Va. 23218
http://gis.vedp.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010620/dc107bac/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20010620/dc107bac/attachment.obj>
More information about the MapServer-users
